one set closer
anyone have a pair of these for sale new or used. thanks up grade.( yep for the rear.)
for the rear? I think Brothers trucks in Carona, CA has them.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I got mine from Early Classics.
#4 | |
67 is sold
one set closer
ttt
67-72 parts collector,…
![]() Join Date: Nov 2002
Don't forget to use an adjustable trac- bar with a 6 inch drop spring. Also need some upper and lower shock mounts and shorter shocks. Check out ECE's stuff,... It will ride GREAT. lolife99.
Lolife, what is the adjustable track bar and what does it do?
Thanks |
If you use STOCK track bar, (the rod from the driver's side frame to the rearend), the rearend will move to the passenger side when you install your 6 inch drop springs. ECE makes an adjustable bar,...It has one end welded solid and the other end is threaded so you can center the rearend back under your truck. Go to their website and look for the "SUPER TRACK BAR" kit.
