Old 08-24-2004, 06:15 PM   #1
highboy_04
highboy_04's Avatar
speedo check?
i've been trying to find a place to check my actual speed. i've got a different gear ratio now and need to figure out how off the speedo is. the tires are the same size so i need a calculator to do the ratios. thanks, Steve
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 08-24-2004, 06:18 PM   #2
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Try this.
Todd
toddtheodd is offline   Reply With Quote
Old 08-24-2004, 06:23 PM   #3
cdowns
cdowns's Avatar
the easy way to do a rough check is go out on an interstate that has mile markers with a stopwatch. with your speedo at a steady 60mph your time between mile markers should be 1minute
Old 08-24-2004, 06:40 PM   #4
Gee_Emm
Get a buddy that has a GPS and go for a ride
Gee_Emm is offline   Reply With Quote
Old 08-24-2004, 06:50 PM   #5
MACKL
Almost done!
MACKL's Avatar
GPS is the way to go. Takes all of the guess work out, no math. It will even give you a reason to buy one. Then it is a tool, not a toy!
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 08-24-2004, 07:11 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
If you are not all that worried about if it was right in the first place, all you will need to do is divide your new ratio by your old ratio.
4.10/3.73=1.10 A 4.10 ratio is 110% of the 3.73 ratio. 3,000 rpms with a 3.73 will be 3,300 rpms with a 4.10 ratio. Your speedo would be off by 10%. 60mph would now be at 66mph on the speedo.
3.08/4.10=.75 if your 4.10 gear was 3300 rpms at 60mph a 3.08 would be 75% of the old 4.10 gear or 2475 rpms. your speedo would be off by 25% You would now be doing 60mph when the speedo says it is doing 45mph.
hopefully I didn't turn any of the numbers around, but it should be correct.
Here are a couple of other sites I have used to help figure this out before.
http://www.novaresource.org/speedo.htm
http://www.bgsoflex.com/speedo1.html
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-24-2004, 09:18 PM   #7
smitty62
smitty62's Avatar
You guys are way overcomplicating this--Cdowns has it right.
If you are really picky, take the deviation in seconds from 1 minute to travel measured mile (+ 0r - seconds) divide that by 60 for the percentage it deviates--that's the percentage your speedo is off.
IE: 58 sec. = 2 seconds deviation, div. by 60 = 3% fast or 61.8 actual mph. Close enough for government work and you never have to get out of cab or buy a $200+ piece of equipment!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 08-24-2004, 10:14 PM   #8
highboy_04
highboy_04's Avatar
alright thanks for the help guys according to that site i am suppose to be going 80 at 3000 rpms with the 3.08 gears but with 3.73 i'm only goin 69.9. thanks, Steve
'67 c10 350/th350
Old 08-24-2004, 10:20 PM   #9
zooza
I checked mine today , parked my crown vic. beside the road and showed the wife how to lock the radar. Then I drove by at 55 mph. she locked it when I flashed my headlights. Found that the 95 mustang gt is off by 5 mph and the 72 c-10 is off 4 mph
55 on the speedo = 50 mph.
My suggestion is to just ask an officer to check you. I do it for people... sometimes when they ask sometimes not! LOL
zooza is offline   Reply With Quote
