Old 08-25-2004, 12:24 PM   #1
FirstGen
Just Don't Stop!
FirstGen's Avatar
late model truck disk brakes on our trucks??
Any body have any idea how difficult it would be to put on some late model disk brake setups on our older trucks? I know that would solve to problems for me. 1 being going from drums to disks and 2 going to the newer smaller hub for cheaper wheel prices and larger selection!
Any ideas anyone? Anyone done this already?
Thanks,
Taylor
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 08-25-2004, 12:44 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
i put 81 disks on mine it stops a lot better now i changed mine from the a arms out it was a unbolt and bolt up thing i also use the power booster and ms from the same truck i had to mod sum stuff there at the booster be sure to use the disturbtion block from the doner truck i learned the hard way about that that was before i learned about this board this is the best board on the net aint it the only thing that was a real problem was the 81 stuff was metric and was a pain to find a metric to standerd adapter for the rear brake line but i found it!
tnblazerk5 is offline   Reply With Quote
Old 08-25-2004, 01:21 PM   #3
Steve Carda
Steve Carda's Avatar
I put the front end from a 73 4X4 under my 68 4X4 and it fit perfect.
68 4x4 402 big block
Steve Carda is offline   Reply With Quote
Old 08-25-2004, 04:40 PM   #4
FirstGen
Just Don't Stop!
FirstGen's Avatar
that's good info but I was really talking about keeping it 6 lug and using the late model like99 up truck set up with the smaller hubs. Any ideas?
Thanks!
TT LSA/6L90e/9"
Old 08-25-2004, 08:08 PM   #5
lock
Insert funny comment.
lock's Avatar
My buddy has my 73+ spindles right now and is fabbing up brackets to mount C5 calipers... that will end up a 5 lug setup though.
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 08-25-2004, 11:21 PM   #6
FirstGen
Just Don't Stop!
FirstGen's Avatar
I wouldn't mind a 5 lug really I was just courious about doing something late model like that. Do you have any more info on what it is going to take to do that conversion? I already bought a LS6 master and brake booster I'm going to put on...
Thanks,
Taylor
TT LSA/6L90e/9"
Old 08-31-2004, 10:42 AM   #7
FirstGen
Just Don't Stop!
FirstGen's Avatar
ttt
TT LSA/6L90e/9"
Old 08-31-2004, 11:29 AM   #8
69sixpackbee
I am going to be adding REAR discs this winter (project). Since I have a Dana rear, the discs from a F**d van will be a piece of cake to adapt. Hopefully I will start on it soon.
69sixpackbee is offline   Reply With Quote
Old 08-31-2004, 01:09 PM   #9
FirstGen
Just Don't Stop!
FirstGen's Avatar
is that 6 lug? I'm not familiar with the Dana rear end's...
Thanks.
TT LSA/6L90e/9"
Old 08-31-2004, 01:43 PM   #10
Nick's683/4
http://67-72chevytrucks.com/vboard/s....php3?t=117428
There is a link to some pics of my truck i put the crossmember out of a 79 suburban in it you just have to drill 2 new holes and ovel out some other ones.
70 1 ton with a 454 and a 4 speed and a np205
Nick's683/4 is offline   Reply With Quote
Old 08-31-2004, 02:41 PM   #11
rascal
are you wanting to do the rear brakes too? I've been thinking about this. I got to get my project truck before i do any thing. looking at a swb 71, my neighbor has. I haven't did a search on the site yet, just registered really. wanting to do 4 wheel disc on it. thinking I'd like to look for a wreaked 99-01 2wd 5 speed, could get a 2500 for the 6.0/ 5speed combo.
rascal is offline   Reply With Quote
Old 08-31-2004, 02:42 PM   #12
69sixpackbee
8 lug.
Old 08-31-2004, 02:50 PM   #13
rascal
good point. I'd want 16" anyway, but it seems to be alot nicer wheels for 6 lug. 1500's is 6 lug, but I'd like to get bigger than the 4.8 motor.
Old 09-07-2004, 03:01 PM   #14
FirstGen
Just Don't Stop!
FirstGen's Avatar
make sure you get an 01 up 6.0l otherwise it will have iron heads not aluminum... You can get a 1500HD pick with the 6 lug and 6.0l, 4L80
TT LSA/6L90e/9"
Old 09-07-2004, 05:57 PM   #15
lock
lock's Avatar
Thanks,
Taylor
Not yet. He just started looking at it. Hopefully Ill know something in a week or two. Does look like I will have to stay with the truck 5 on 5 lug pattern though which is probably best for most people here.
- Mark
-My Build Thread...
-70 Camaro
