need info on distributors
the 68 wouldnt fire so i traced it down to a burnt wire going into the coil, what are some causes of that? what brand, type coil should i replace it with? Im thinking of getting a whole new distributor since it wasnt rebuilt when i put the truck together, any help as to what to look for?
heres a pic of what happened, any guesses? And why is it that if you lay anything on the floor it atracts cats like a magnet?
I see you have a newer electronic version. Check the plug wire closest from that termial to see if it was arcing over. You can get a new one at NAPA or the dealership. Might want to get new plug wires too.
![]() Join Date: Feb 2001
Wages if ya get a new distributor call me.
binford may have nailed it, but I'll take a guess too.
Did the red wire (power) rub on the metal plates of the coil (ground)? That would explain the sudden loss of smoke in the wire! Good Luck!
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
thanks for the help, ill look at the plug wires when i get the truck home, its a few hours away right now.
Hey lost wages your problem is a missing ground strap-check photo-you can pick up one at parts store (most are all metal).
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
its alright wages...im gonna put a huge belt buckle on and go over and check those wires out for ya real good......
pm sent, little buddy, lol.
