Old 08-26-2004, 12:01 AM   #1
DirtDoctor
Exclamation Help! Need some measurements on a 47-55!
Would anyone with a 47-55 truck be willing to take some frame height measurements for me?? I am doing a frame off on a 50 3100 and need to know top of frame to ground measurements at front and rear. Am installing a TCI IFS package and need to have the frame on jackstands at something close to a finished ride height. If you only have stock ride height that would help, but would prefer some measurements on a nice lowered stance! Thanks in advanced. I have tried posts on a couple of other sites without much luck!
DirtDoctor is offline   Reply With Quote
Old 09-05-2004, 10:27 PM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Looking at Chevrolets specs for a 49, the hight to the top of the frame at the CL of the rear axle is 21 11/16 inch at the rear and looks to be the same at the front. This is stock height, maby somebody else could give you some dropped measurements.
NeCrOmAnCeR is offline   Reply With Quote
Old 11-04-2004, 08:27 PM   #3
rlc02
I am doing the same thing to a 52 Chevy truck with the TCI IFS. I already had the frame out of the truck before I ordered the IFS. I could also use some measurements.
rlc02 is offline   Reply With Quote
Old 11-05-2004, 02:59 PM   #4
Heatwave
Heatwave's Avatar
I will measure my 55 1st series right now. I have a fatman MustangII front end with stock spindles. the rear is still lowering blocks on leafs.
1955 Chevy Series 1
Heatwave is offline   Reply With Quote
Old 11-05-2004, 03:09 PM   #5
Heatwave
Heatwave's Avatar
11.250 " front frame (in front of front tire)
19.75 " rear frame (behind tire)
1955 Chevy Series 1
Old 11-05-2004, 11:53 PM   #6
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Heatwave,
Nice truck!
For all those who have not posted you machines in the Show us your stuff. thread (including myself), please do so. It helps with Truck of the month nominations among other functions of the board and moderators.
Thanks, Denny
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 11-08-2004, 11:01 AM   #7
rlc02
Thanks for the info Heatwave. The stance you have on yours is about what I am looking for so I will go with your measurements.
Nice truck
Old 11-08-2004, 11:25 AM   #8
Heatwave
Heatwave's Avatar
Thanks and good luck with your project.
1955 Chevy Series 1
Old 11-18-2004, 01:30 PM   #9
solidaxel
solidaxel's Avatar
.......H W, would you measure the front and rear fenders from the center of the axle at the bottom lip of the fenders to the ground, and what size tires are you running front and back?
Did you say that you are running the stock rear spring and lowering blocks on the rear? are they 2.25" blocks?
Thanks,
Bob
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-18-2004, 01:46 PM   #10
Heatwave
Heatwave's Avatar
Sure I'll do it right now!
1955 Chevy Series 1
Old 11-18-2004, 01:50 PM   #11
Heatwave
Heatwave's Avatar
If I understand correctly here are the measurements:
2' exactly from center of axle fender to floor Front
2' 1 1/2" rear
tires are 225X60R15's
Lowering blocks are 3"
Let me know if this is not what you were after.
1955 Chevy Series 1
Old 11-19-2004, 06:29 PM   #12
solidaxel
solidaxel's Avatar
H W thanks, is that 24" front and 25 1/2" on the rear from the bottom of the fender to the ground.
Do you have any spring wrap up when you leave VERY hard off the line with 3" blocks under the axle, do you have a posi?
LS 3 4L70E
Old 11-19-2004, 06:40 PM   #13
solidaxel
solidaxel's Avatar
Hey Dirt Doctor, sorry to hijack your post !!! Welcome to the finest board on the web!
My truck is up on blocks and the sheet metal is all removed. I can take some measurments on the frame but not in relation to the ground let me know if I can be of some assistance.
What are you going to do with the rear end ?
HW has a good looking truck and it sets right in that photo, thought I would see if my measurments were the same while I was looking at this post.
LS 3 4L70E
Old 11-19-2004, 07:46 PM   #14
Heatwave
Heatwave's Avatar
I'm putting a 4 bar in real soon...I'm afraid to come off the line real hard with this setup. Also thinking about adding a blower, so the springs have to go!
You can get the 4 bar at Chevy Duty for $399.00 without the coil overs. If your doing it now from the frame up....I wish I had done it from the start!
And yes those measurements are correct.
Good luck,
HW
1955 Chevy Series 1
Old 11-19-2004, 07:52 PM   #15
solidaxel
solidaxel's Avatar
HW you have a PM !!
LS 3 4L70E
Old 11-20-2004, 11:41 AM   #16
Apache
Apache's Avatar
I have a 54 sitting out front getting ready to be worked on, I could use it to get STOCK measurements off of it. But you were wanting the measurements on a slightly lowered stance. Plus this one has no engine so the front would be higher then it really should be.
54 Chevy Bel Air 4dr powerglide
54 Chevy SWB
58 Chevy Big Window SWB Fleetside project
58 Chevy LWB 235/4spd
76 Chevy Nova 350/TH350 4.88's *10kmiles on "new" engine
79 Chevy 4x4 SWB 350/4spd 3/4 ton
81 Mazda RX7
84 F@!d Mustang
96 F@!d Ranger 2.3L/5spd
Apache is offline   Reply With Quote
Old 11-20-2004, 02:46 PM   #17
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I have a 49 3/4 ton on 275x60x16 that is at stock height if that'll help.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
