Old 08-26-2004, 12:31 AM   #1
xchief1320
anyone know what Chevy a N/P 207 came in?
Reason i ask is i just got a Jeep Wrangler with a TPI V8 and it has a 700R4 and a N/P 207..The guy told me the 207 and the 700R4 were out of the same vehicle..I want to upgrade to a stronger transfer but was wondering what i should look for..The 207 has the POS transfer shifter with a buttom on the top of the knob you have to push to get it to move to 4L,4H,N,ect..and the Jeep has a body lift and a transfer case drop on it and the shifter only sticks inside the cab 2" or so.And i have searched for a longer shifter for the 207 with no luck..
So does anyone have any info on this setup?
Any help would be greatly appreciated..
Steve
xchief1320 is offline   Reply With Quote
Old 08-26-2004, 01:23 AM   #2
1969 GMC
1969 GMC's Avatar
That is out of a S10/S15 pickup or blazer.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-26-2004, 02:11 AM   #3
alf4444
alf4444's Avatar
I would just find a good 205 and swap it out
2011 CCSB GMC 2500HD DMAX
73 GMC 3/4 ton 4x4
96 Chevy 1500 STD Cab Shortbed Z71
Owner of WickedWolfRC.com
alf4444 is offline   Reply With Quote
Old 08-26-2004, 10:47 AM   #4
xchief1320
so a 205 would be a direct swap? any write ups on the swap if it isn't a direct swap..And one last one..What can i look for in the JY that has a 205? is it that much stronger?
Thanks alot and VERY sorry for all the questions..
Steve
Old 08-26-2004, 01:23 PM   #5
alf4444
alf4444's Avatar
NP 205's came in ford chevy and dodge fullsize rigs. Find a GM NP 205 that was mated to a th350. The output spline on a th350 and a 700r4 are the same. You might have to have the leangth of your dlines changed but thats not too expensive. NP205's our one of the strongest tcases out there.
73 GMC 3/4 ton 4x4
Old 08-26-2004, 01:40 PM   #6
71swb4x4
71swb4x4's Avatar
Post some pics of the engine compartment of that thing. I am doing a TPI conversion on my truck right now and its always fun to see one that are finished
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-26-2004, 01:43 PM   #7
xchief1320
no problem i'll go out and take a few right now and post them up..
Steve
Old 08-26-2004, 02:18 PM   #8
xchief1320
Here are a few pics.The jeep uses a Painless harness,and the ECM is mounted as high up under the dash as you can get it.
Also on the first pic you can see how short the transfer shifter is..I keep it pulled off till i need to use 4wd then i screw the shifter on..it needs to be about 4-5" higher to make it comfortable and to be able to run a boot on it..
Steve
Old 08-26-2004, 05:20 PM   #9
1FaastC10
1FaastC10's Avatar
remove the body lift, and get some smaller more agressive tires. i never did understand the point of having big mall terrains.
1FaastC10 is offline   Reply With Quote
Old 08-26-2004, 06:04 PM   #10
xchief1320
thanks for your opinion but i'm about to lift it even higher and put 38's on it..I'm not a rock crawler or redneck that likes to go out in the woods everynight shining for deer.I like the jeep cause it's fun.and even though it would still be fun on 33's it's normal..every jeep around here is on 33's i want something that stands out..The roughest it will ever see is a trip to Ocala national forest for some trail riding.that's about it..
But again thanks for your opinion on the Jeep..
Steve
Old 08-27-2004, 08:36 AM   #11
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Any way to weld an extenton to your shifter and then put the handle on that? There has to be sopmething you can do with it.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 08-27-2004, 10:55 AM   #12
xchief1320
The only problem is the 207 has the button in the middle of the shifter you have to push to allow you to move it..IF i could do away with the button then it would be easy to extend it.I'm not sure if i can do away with it.It might not want to stay in gear if i do.the button moves the shiftergate detent,without it there would be nothing to hold it in the gear i put it in..
Steve
Old 08-28-2004, 12:52 AM   #13
xchief1320
Also i just found out the N/P 205 has a pass side front Drive shaft..The jeep is a Drivers side..So unless i switch out front end that won't help me..What i did find was a N/P 241 it is a direct bolt in from what i have read so far..Anyone know what years would work with a 700R4..seems like it's in the 88+ fullsize GM that seem right?
Steve
Old 08-28-2004, 01:50 AM   #14
1969 GMC
1969 GMC's Avatar
yes, the NP241 you want came in 88+ IFS trucks with driver drop. There was another version of the NP241 that came in V-series suburbans and blazers, that has the passenger side drop, so obviously steer clear of that one.
or, you could make the shifter longer by adding tube to the stock shifter.
Oh, and Ford NP205's are driver drop...but good luck mounting one of those to the r4 cheaply!
1969 GMC K2500
1996 Honda Accord
Old 08-28-2004, 03:01 AM   #15
1969 GMC
1969 GMC's Avatar
It would be nice if we knew where you live, because I found a NP241 in PA for sale for $25 or 2- 12 packs of Bud Light bottles.
LOL, nevermind, I did not read all the way down. I see you already found that guy.
1969 GMC K2500
1996 Honda Accord
Old 08-28-2004, 09:38 PM   #16
xchief1320
Yeah i have been looking all over..lol..
I'm in Jacksonville,Florida
Thanks for looking out for me though..hopefully he will get back to me.I have also looked at car-parts.com to see if any of the local yards have one.so far none have responded to my e-mails..
Steve
Old 09-01-2004, 09:39 PM   #17
Gunny
runnin on empty
Gunny's Avatar
another option is the 208C it has the same dimensions as the 207 but is a little lower geared. the 207 is what the s-10's had in them. after you lift it (go with a suspention lift and not the body lift - old man emu is one of the best lift kits for Jeeps)
and get the 38's give me a holler - I am looking for some 33's to put on my suburban.
Gunny
88 GMC Suburban - 6.2 Diesel 4x4
87 Jeep Cherokee - 6" lift, 32 bfg's, way too many mods to list.
65 Thunderbird - Stock
United States Marine Corps
SEPIUS EXERTUS, SEMPER FIDELIS, FRATER INFINITAS
"Often Tested, Always Faithful, Brothers Forever"
Gunny is offline   Reply With Quote
Old 09-01-2004, 10:11 PM   #18
xchief1320
The jeep already has a 4" BDS SUA lift along with a Shackle reverse up front which adds another 1" of lift.Then the 3" body lift..so it has 7" in rear and 8" in the front.it needs a set of shackles to even it up in the rear.they will come after i do the rest of it...
And it's on 35/12.50/15's's now.i am thinking of going to a SOA and running 38's but now i have decided to keep 35's on it but to run 2" springs and a SOA so i can get good flex.
Any idea what the 208C came out of?
Steve
Old 09-01-2004, 11:31 PM   #19
Gunny
runnin on empty
Gunny's Avatar
early 80's to late 80's full size (my 88 suburban Diesel has one) still a chain drive so not as tough as a 205 but it will bolt right up to your tranny.
