Old 08-26-2004, 05:24 PM   #1
Help - 6 Banger - Help
Question for all you mech experts and all. The 250 in my 82 C10 ditched a rod. The top end is all good. Is it possible to take the top end (integrated head assembly) off the 82 and put it on my 70's 250 block. I want to keep a six in the 82 and I need the upper end because of all the accessories the 82 has and the 70 doesn't. My 70's engine is solid, but the AC, pwr steering and all from the newer truck won't mount up.
Thanks for any help.
Old 08-26-2004, 05:25 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, the integral heads and non intergral heads interchange with each other.
Old 08-26-2004, 06:35 PM   #3
That is good to know. I thought so, but you just never know what seems obvious isn't. I guess now I'll have to find another engine for the 70. OH darn, I guess I'll just HAVE to use a V8 now .
Thanks TX Firefighter.
Old 08-26-2004, 07:44 PM   #4
krue
Designated A-hole!
krue's Avatar
Darn the luck Bill. How did you blow up the 82?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-26-2004, 08:45 PM   #5
I didn't Krue. The owner did. I know she wasn't hot rodding it (this time) because she was with her mom. The bearing let go as she was getting on I10.
Old 08-27-2004, 07:44 AM   #6
JJR
JJR's Avatar
As mentioned, the blocks should swap but there may be a problem mounting the compressor. The 82 block probably has an area next to the timing chain cover that one of the A/C support brackets bolts to. If the block in your 70 truck is original, it won't have the mounting holes next to the timing chain cover. Originally, the compressor was mounted to the side of the cylinder head on a 70 truck 250.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 08-27-2004, 09:50 AM   #7
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Beware: Those integrated heads are notorious for cracking. Have it magnafluxed before you install it, just for GP
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
