Help with brakes and spindles
I have a 69 longbed which is being bagged. For the front ive taken the crossmember out and chopped it 1.5inches. I went and bought some 3" drop spindles from chassis tech. It says i need disc brakes and an upper ball joint from a 73-80 c10. Do any of you know how to convert my front drums(power) to accept these disc brakes. Do i need a new master cylinder, proportioning valve, lines, ect. Does anyone know a good place to get some discs, calipers, hubs, and whaterver else i need?
67-72 parts collector,…
![]() Join Date: Nov 2002
Early Classic Enterprises. They have everything for our trucks.
NAPA, AUTOZONE etc.
Rest in Peace Ed. Thanks for all the good times. |
ive gone to these websites i just need to know am i going to have to get a proportioning valve, different master cylinder and whatever because im going to grab some discs hubs and calipers off a junkyard truck
Got Light Emitting Diode?
you will need a disk/drum master and prop. valve. you said it was already power so you wont need the booster.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
MC & PV for disc/drum. Rotors, bearings, loaded calipers, for whatever spindles you have, 73-80? Hoses they need banjo to fit calipers on one end and your hard line on the other. Check this post its about 71-72 calipers don't know if they have the same size fitting.
http://67-72chevytrucks.com/vboard/s....php3?t=115091
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 08-27-2004 at 12:23 AM. |
