Old 08-26-2004, 07:41 PM   #1
ljbear
ljbear's Avatar
67 SWB Fleetside Bed FS, 67-72
I have a nice Short Fleetside bed from a 67 Chevy. Bed is in very nice shape considering it's age. It's sitting on the original chassis that has been cut off and used as a trailer since the mid 80's. I've been using it for dump runs and light hauling, intending to use it for a project I was planning on. The trailer works OK, but rocks as it's on the coil rear suspension, so it's not really a hauler. The bed itself is in nice shape. The right side has a slight crease you can see in the picture. Left side just a few minor dings. Pockets are nice and there are no holes in the top rail. There were 4 hooks mounted on the side so there is some small holes to be welded up. No original trim so no holes there to contend with. Floor is decent with a dent right between the wheel wells. It's something that could easily be straightened, no rust. Wheel wells are very nice, a few small dings. The front panel has some dents and bent. It could be straightened as well, or I have an extra panel if interested. Same with the tailgate, a few dents, but solid. The tailgate is flat on the bottom edge so it's very fixable. This will work for other years, 68-72, but would need the lights added if you wanted them. Tow it away, $700 obo
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 08-26-2004, 08:58 PM   #2
Bob Moore
67 short fleet
You have a PM
Thanks - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 08-28-2004, 01:19 AM   #3
ljbear
ljbear's Avatar
More pictures will be added sometime on Sunday
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 08-29-2004, 09:53 PM   #4
ljbear
ljbear's Avatar
More Pictures
For those that requested here are the additional pictures. Floor is relatively flat. Nice at the rear where they are usually smashed from loading. The area in between the wheel wells is probably about 8-12" across. The picture of the front panel looks worse than it is, and again I have another one that is better if needed. I forgot the two holes in the floor near the front panel. Looks like maybe a toolbox or something was mounted there?
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 09-02-2004, 02:03 PM   #5
ljbear
ljbear's Avatar
I've told a few people $600 with the extra front. Also, it can get delivered along I-5 between Sacramento and Tacoma the weekend of the 11th, for an additional $75, but would have to be just bed, not trailer part.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
Old 09-03-2004, 06:42 AM   #6
NORCAL_GUY73
NORCAL_GUY73's Avatar
northern cali here also. anythig you may want to trade for the bed, i am in need of one but low on the dollars. let me know, I am o ver in ukiah 707.
thanks
NORCAL_GUY73 is offline   Reply With Quote
Old 09-04-2004, 12:33 PM   #7
ljbear
ljbear's Avatar
NorCal it's sold. Do you need an entire bed?
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
