Closed Thread
Old 08-26-2004, 08:01 PM   #1
TIMSPEED
TIMSPEED's Avatar
I think I only got 4" out of my flipkit!! WTF?
OK, how do you measure how much drop you got with a flipkit? It's from the bottom of the spring pack, to the centerpoint of the axle tube, right? If so, it's 4" at best. (Looks more like 3.75" though)
Is that right?? or am I measuring it wrong?
I have a few cars...
See Them Here
TIMSPEED is offline
Old 08-26-2004, 08:16 PM   #2
ocbaud
Garage Queen Material
i measured from the wheel wells
ocbaud is offline
Old 08-26-2004, 08:17 PM   #3
TIMSPEED
TIMSPEED's Avatar
I didn't
See Them Here
TIMSPEED is offline
Old 08-26-2004, 08:22 PM   #4
plumbcut
california fill
measure the centerlines of the old bolt hole vs. the new bolt hole??
plumbcut is offline
Old 08-26-2004, 08:38 PM   #5
patgizz
patgizz's Avatar
top of springs to bottom of axle tube if your flip is already in. so you should be right around 6" taking your 4" and adding half an axle tube. you've gone down a whole axle tube and the whole stack of springs.
patgizz is offline
Old 08-26-2004, 09:24 PM   #6
BaggedC10
Under construction!
BaggedC10's Avatar
The proper way would have been to measure from the center of the wheel to the fender lip (Both sides) before/after installing the flip kit.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline
Old 08-27-2004, 03:17 PM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
I agree although its too late for that now
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline
Old 08-27-2004, 03:57 PM   #8
TIMSPEED
TIMSPEED's Avatar
Well, ok then...before, I had 32" AT tires on it, and the fenders were ~2" away from the tops of the tires. So, divide that in half, and it's 18" from center-to-fender. NOW I have 28" tires with the flipkit, and the fenders are ~1" away from the tops of the tires. That's 15"...See what I'm saying?
See Them Here
TIMSPEED is offline
Old 08-27-2004, 04:37 PM   #9
1FaastC10
1FaastC10's Avatar
who says your 32" tires were actually 32" tall, and who is to say that your 28" tires are 28" tall? actual tire size can vary just by rim size. why worry about it all that much? just lower it until it looks good and dont worry about the numbers.
1FaastC10 is offline
Old 08-27-2004, 08:35 PM   #10
Tom
driving is in my blood
Tom's Avatar
Exactly. Also it depends on your spring pack. My 8 leaf HD spring pack gave me more like 6-6.5" of drop on a 5" rated kit.
Tom is offline
Old 08-27-2004, 08:38 PM   #11
TIMSPEED
TIMSPEED's Avatar
nevermind, now that I look back at the picture, my rear fender was about 4" above the tire, so that would be 20", and now it's at 15"...so it's all good.
See Them Here
TIMSPEED is offline
Old 08-27-2004, 11:54 PM   #12
79Silv4x4
Workaholic
79Silv4x4's Avatar
WTF WTF WTF??? Not trying to be too rude but seriously. Your inital post indicates that you (think) you only got 3.75 drop out of a 4 inch flip (close enough for anyone!). Mfg. literature will tell you that 4" is average and yours will depend on your individual spring setup. You took no starting measurements so you have no reference point--making this thread semi-pointless.
Finally, after everyone offers their input you claim everything is 'cool' now because of a mystery photo indicating that you now have 5" drop from your 4" flip (yet another of your 'estimates'). Do it right--remove the flip kit, take some measurements with the tires/wheels you plan to run, install the flip kit and then measure. Better yet, look at it now, if you like the stance leave it the hell alone and not concern yourself with (.25 inches)--go fix somthing else on your ride. I'm sorry if this seems rude but what's the point?????
79Silv4x4 is offline
Old 08-28-2004, 04:21 AM   #13
TIMSPEED
TIMSPEED's Avatar
To up my post count, of course :p
See Them Here
TIMSPEED is offline
Old 08-28-2004, 10:24 AM   #14
79Silv4x4
Workaholic
79Silv4x4's Avatar
The Rules
See #13
13) No posts meant strictly to drive your post count up, or otherwise abuse server resources. If you make a post to drive your post count up, for an avatar etc. two times the number of posts made to increase your post count will be removed from your count, you will not be allowed an avatar untill 200 posts.
Old 08-28-2004, 02:07 PM   #15
Liz
Catchy title goes here..
Liz's Avatar
Liz is offline
Old 08-28-2004, 10:18 PM   #16
Josh
He's got mean nasty FANGS!
Josh's Avatar
Post count has been adjusted accordingly due to post whoring.
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline
Closed Thread
