Old 08-26-2004, 11:25 PM   #1
9teen69
9teen69's Avatar
Lift installation advise wanted
I decided to go with a TC 6" lift from ORD - springs all around. Any advise on where to start or what to avoid so I don't end up doing this...
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 08-26-2004, 11:58 PM   #2
Mudder
Mudder's Avatar
Lube all the bolts a few days before ya start or just use a torch. They can be a pain getting loose. Use good jack stands and have a good floor jack for raising and lowering the axles. Don't get under the truck anymore than you have to. Be safe. Do the front then go to the back once you have the front finished.
Mudder is offline   Reply With Quote
Old 08-27-2004, 08:50 AM   #3
Bobalouie
Fetzer Valve Technician
Bobalouie's Avatar
I have heard that after you install the springs that you will want to leave the hardware a little loose and tighten it all down after you set the truck back on the ground, in order to avoid preloading the springs. Does anyone know if that is correct? I will be doing a lift soon myself.
1972 Chevy K10 SWB
Bobalouie is offline   Reply With Quote
Old 08-27-2004, 08:54 AM   #4
Mudder
Mudder's Avatar
Yes and retighten the ubolts after you have driven a week or so then do it again to make sure they are staying tight.
Old 08-27-2004, 09:47 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Also if your not going to reuse the stock u-bolts/spring hardware cut it off you'll be ahead of the game for sure. I used an angle grinder made the job go so much faster. For hardware get an assortment of 5" long grade 8 bolts in 9/16", 1/2" and 7/16" w/ fine threads, washers and pinch nuts. If you have the bracket bolted/welded to the frame behind the front left shackle take it off, the strap in the front(same side) might have to come off also. Lube all of the bushings. Replace the bushings in the frame also.
Disconnect the rear brake line before you start the back.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-27-2004, 10:20 AM   #6
cochino12
It followed me home?
cochino12's Avatar
And make sure you get a BIG HAMMER to get the steering arm off.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-27-2004, 10:37 AM   #7
Scrubby
Check out GMTrucks.org
The trick I learned on the steering arm was to hit it down and up alternating. Not just up like you would think. Eventually the cone washers will walk out a bit and you can pull them out with pliers, then it comes off easy. Still, I think that was the hardest part of the job.
Scrubby is offline   Reply With Quote
Old 08-27-2004, 10:45 AM   #8
wildwood
wildwood's Avatar
My 6" Superlift came with a 4" drop pitman arm it works perfect and saves having to change the steering arm I would recomend that to anyone. You can also buy them seperately from Superlift. Can't find the email address of the guy I was getting the parts from though.
You can't get out if ya don't get in
wildwood is offline   Reply With Quote
Old 08-27-2004, 10:53 AM   #9
CHEVYJEFF
CHEVYJEFF's Avatar
get cross over steering, if you can.
get extended brake lines
get hd shackels and greaseable bolts from o.r.d.
get new ujoints
measure for new drive shafts
multiple cans of pb blaster
bribe friends w/ beer
have a torch, saws all, grinder and cut off wheel ready
do rear first than front
http://members.cardomain.com/chevyjeff
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
97 REGAL LSR 2100 (BOAT)
CHEVYJEFF is offline   Reply With Quote
Old 08-27-2004, 10:53 AM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I had to heat my steering arm up with a torch and it popped off.
Old 08-27-2004, 11:57 AM   #11
9teen69
9teen69's Avatar
Thanks for all the great advise. I did buy greaseable bushings from ORD and stainless brake lines.
I started disconnecting the brake lines last night. I also want to remove the front calipers so I can replace the studs/lugnuts - after removing the hubs how do you get the caliper off - do I need a special tool?
Old 08-27-2004, 02:20 PM   #12
Grim Reaper
Check the depth of the spring pins. Sometimes the pins will bottom out and not thet the sping clapm completly down. When that healles it is very easy to shear off the spring pin and have the axle move on you.
New U bolts all the way around but I'm sure Stephen advised that when you bought from him.
BE VERY CAREFULL ON THE FRONT SPRING PLATES. Stock GM front springs are 2.5 inches wide. the replacements will be two. You can bend thos top plates by over tightening.
Get full weight of truck on springs before tichtening everything up. That was mentison but it's very imortant. recheck that everythign is tight after a couple weeks of driving.
ORD BRACE is a must. It makes even a stock truck so much better.
If your going to run a sway get the ORD disconnects or your going to have bad bumpsteer.
A K5 is very goofy ballance. Have jack stands at the frame horses as well as under them. Because of the shape of the frame you cannot get the stands far enough apart. You drop the axle and the truck may try to flip back the other way. Depdog and I about dropped a K5 on ourselves because of that not once but twice. Darwin was gunning for us that day.
Have Come along handy. some times it takes a little coaxing to get things lined up.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 08-27-2004, 04:02 PM   #13
9teen69
9teen69's Avatar
You lost me here.
What is the "ORD BRACE" ?
Old 08-28-2004, 10:58 AM   #14
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
There's a pin/bolt that holds the spring pack together it also centers the spring on the axle. You may have to clean the head of the bolt a little to help it fit perfectly. you do not want to make the hole bigger or deeper.
The brace is a steering box brace that helps keep the gear box and frame together. This is a problem area on all solid axle chevys.
Old 08-28-2004, 05:01 PM   #15
Grim Reaper
Originally Posted by 9teen69
You lost me here.
http://www.offroaddesign.com/catalog/steeringkit.htm
Fire up your truck and have somebody turn the wheels lock to lock and watch the steering box. That brace will fix the scary thing you see. With lift that gets worse.
Grim-Reaper
