Old 08-27-2004, 09:50 AM   #1
Brently
Raising the front end of my 71 1/2 ton
I want to raise the front end of my 71 swb about 1 1/2 to 2 inches to sit it level. I have went the route of trying to put coil spacers in there but no luck. I have tried the screw in kind and the rubber spacers and still no luck. What about putting a pad above or below the entire coil? has anyone ever raised there front end before? thanks, Brent
Brently is offline   Reply With Quote
Old 08-27-2004, 10:27 AM   #2
sactoC10
71 DELUX
sactoC10's Avatar
I've never raised one of these trucks, but DAYSTAR makes upper and lower spacers for coil springs that work very well. I believe that they manufacture them in 1/2" increments. Here is a link to one of the 4x4 suppliers that sells them.
http://www.4wheelsupply.com/cat.cgi?...spring+spacers
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 08-27-2004, 10:40 AM   #3
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
You might look into 3/4 ton front springs .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 08-27-2004, 01:28 PM   #4
69 Short Fleet
I did by accident, I installed a 1 1/4" swaybar on the front and it raised the front end @ 1" (LOL) but I'm not complaining, Doug
69 Short Fleet is offline   Reply With Quote
Old 08-27-2004, 01:31 PM   #5
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I don't think 3/4-ton front springs will do anything for the ride height, but if it is a small block truck putting in big block front springs will.
badpeanut is offline   Reply With Quote
Old 08-28-2004, 01:26 AM   #6
hanssolo
hanssolo's Avatar
Coil-over shocks will raise it about 1" to 1 1/2". Find at most auto part stores.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 08-28-2004, 07:32 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
That would scare me on the front end. The upper shock mounts on these trucks are notorious for getting loose and wallowing out the frame anyway, I fear that the coil over shocks would be too much for the upper mount studs. Problems would ensue.
