Old 08-27-2004, 10:08 PM   #1
ratrod67
ratrod67's Avatar
Fan shroud question
I just upgraded my 67 with a 4 core radiator. My small block shroud no longer fits. What shroud do I need? I have a small block in there on the small block mounts.
ratrod67 is offline   Reply With Quote
Old 08-27-2004, 10:48 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Something is wrong then. You have the short pump front setup don't you? The shroud should still be fine with the thicker radiator.
Old 08-27-2004, 10:58 PM   #3
ratrod67
ratrod67's Avatar
Yea, I have the short pump. I had to move the upper and lower brackets on the passenger side to the outer set of holes. Now my shroud wont fit due to the brackets being spaced farther apart and the shroud's not wide enough.
Old 08-27-2004, 11:19 PM   #4
jhow66
jhow66's Avatar
Get 2 more brackets and use them in the old holes-now shroud will bolt where it use to be.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-27-2004, 11:22 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
How about the shroud for an A/C truck, isn't that a differefnt P/N from a non-A/C truck? And didn't A/C trucks automaticly get a 4 row rad?
Old 08-27-2004, 11:51 PM   #6
junkyardjohn
junkyardjohn's Avatar
CAN SOMEONE TELL ME WHAT THE DIFFERENCE IS BETWEEN AN AIR & A NON-AIR FAN SCHROUD IS?? (BESIDES THE PT. #.) JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-28-2004, 05:30 AM   #7
Tx Firefighter
I'm pretty sure you don't have a small block shroud then. Every small block shroud that I've ever had, mounted in the wider hole set. The narrow holes were for 6 cylinder radiators. All V8 radiators were wider, even the 2 and 3 core ones.
Old 08-28-2004, 08:30 AM   #8
Zeke
Active Member
When I took the rad out of my truck the end cap fell off. It was cheaper to uprade to a 4 core than to fix old 3 row rad. Had to order larger brackets and my old shroud did not fit anymore. The top lip stuck out too far and the bottom cutout for the hose didn't fit. I am running without one with no problems. Org. 307 V8 3 core rad. LMC catalog list 4 different PN for shrouds but I am not sure which would work or what the differences are.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 08-28-2004, 09:31 AM   #9
66nova383
I solved that problem by switching to dual electric fans with shroud from Wes at classic heartbeat. Very easy install and really clean look.
66nova383 is offline   Reply With Quote
