Premium Level Member
aluminum polishes -- what works best for you?
I just picked up an outer 69 grill (daily driver condition) for my 69 blazer. Pretty good deal, got the inner(perfect shape) and outer (some dings) , both for $13 ! Today was Pick n Pull 1/2 off everything today. NOW, I tried to shine it up with some Mothers Mag/Aluminum polish, but it was not as good as i expected. Is there something better, perhaps a little more abrasive in a non scratch way?
I have used Mother's on that same part with pretty good results. I have found though that if I use to much it doesn't work as well as if I use just a little. I usually put just a little on at a time and try to spread it out a lot. Then I often do it a second time just for fun!! (and to make my fingers ache).
Hope that helps, it's the only stuff I use, so no other brand experience.
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt 2008 Kawasaki Concours 14 ![]() 1997 Harley-Davidson Soft Tail Custom 1948 Chevrolet Coupe (project) 1972 Porsche 914 |
![]() ![]() Join Date: Dec 1999
This is the only aluminum polish i use now.
http://www.awdirect.com/awdirect/fin...m?itemid=10230 www.awdirect.com Works better than anything else.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
Wenol is a very good polish. It comes in a tube. You can get it at some auto parts stores or at car shows.
![]() Join Date: Feb 2001
California Customs Purple Polish and oxidizer. Fine69 sorry, I bought two bottles of the Bushes this summer thinking it might be better than the Calif. Customs but it wasnt and I ended up giving it away to the local Fire Dept. Sometimes different products will work better for different things also. I have never used anything on a grille. I just know for polished wheels, tool boxes, etc, theres nothing better than CC's.
Fine...pm me your address. |
Mike
The grill is anodized.To polish it with mothers,or other brands,You need to remove the anodizing with oven cleaner.Remove the anodizing by spraying on the oven cleaner and letting it sit for 5-10min,then hose it off.May need to repeat.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Thanks everyone. I'll go see what the local auto parts has. The CC stuff sounds good, but probably not avail locally(?).
#8 | |
oven cleaner.....hmm. I'll try it on the grill i removed first. Cool tip, thanks! |
Mike
You can hammer out the small dings,then use fine wet/dry paper to smooth the grill.use 600,1000,then finish with 1500 or 2000,then the aluminum polish.The grill will almost look like chrome.Sounds like a lot of work,but the sanding goes quick.
What me ugly?
A 1500-3000 rpm buffer with a starched wheel, Jewlers rouge (fine grit = white, medium=green, heavy=brown, overkill=black) & blue magic hand polish worked the best for me - the blue magic has a silicone sealant to protect the open pore aluminum from road crap & the weather
`70 C-10 LWB Big & Ugly, like its owner... 307 SB - 600 Holley, Offenhauser 360 - Muncie 465, 3:73 Posi, 33" BF-G`s I like my trucks like my women... big & old with 33" feet. ![]() |
Drive it like U stole it
jakeslim check this out . This Is my second grill I have done
http://67-72chevytrucks.com/vboard/s....php3?t=115601
71 custom 10 swb 72 nova ss 72 nova custom 87 s10 96 burb 94 camry 53 5 window 3100 |
#13 |
heres another . This the first one I did.
http://67-72chevytrucks.com/vboard/s...d.php3?t=67598
#14 | |
Thats the Hillbilly way
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
#15 |
Welll....all done! I went out and bought some oven cleaner, and some 1000 and 2000 grit sand paper. Sprayed the grill with the cleaner and let sit for a bit. Hosed it off and let it dry(2 minutes considering the heat out here!). First I went with the 1000 grit, wiped, then the 2000 grit. Next I used the Mothers aluminum polish to finish it up. WOW. Amazing shine. I also taped it it up and sprayed all the accent paint(black). Also painted the inner grill black to make the grill really stand out. NICE! The grill cost me $13(inner and outer) so I'm happy. Is it perfect? No. Is it much nicer than my old smashed grill? Yep.
Thanks for all the tips. jakeslim |
