Insert funny comment.
![]() Join Date: Dec 1999
Pretty excited to be putting the truck back together. So far things are going great. Got the whole back half of the suspension back on. Long way to go!
Fresh from getting media blasted: ![]() 3.73 posi rear end(from my IROC-Z) ![]() ECC hidden hitch, tank, super track bar... etc ![]() Now to tackle the front end and mock up the engine.
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
67 is sold
Very nice work
![]() How was the install of that ECE tank? |
#3 | |
Pretty easy. You replace the rear crossmember and it has two mount bolts. Then remove the small cross member in the middle. Mount up the tank and drill the mount holes on the sides... then bolt it up. Used a jack to hole it up and managed to get it installed by myself pretty easily. Very nice tank but its not cheap. Luckily I got it a little cheaper from a board member.
67 is sold
Yeah, I've been looking a them. ECEs setup is a bit pricey
![]() Thanks - Frame looks great ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Lock, what are you doing about the bolt pattern on the IROC rear vs the truck front?
67c10step- I've always been very happy with my ECE parts. By the time I get them put onto the truck, I've always forgotten about the price and been very happy with the quality. Never any issue with ECE stuff.
#6 | |
