AC Problems
Wanting to see if anyone had any ideas. Twice in the last two weeks my AC stopped blowing. I checked the fuse the first time and it was OK, then started the truck and everything was working again. Today, while running errands at lunch, I got back into the truck and no AC. The fan/blower is not running at all.
My initial thoughts: could be a switch issue, could be a wiring issue (short, etc.). Any thoughts as to what could be causing this intermittent problem. It is to damn hot for no AC. ![]()
Hook'em |
re
blower relay????
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD ![]() |
Fetzer Valve Technician
Mine does the same thing. It sounds like the fan speed switch. At least that is what is wrong with mine. They are cheap, and you can get them almost anywhere.
1972 Chevy K10 SWB |
I pulled this off just a minute ago. Is this the fan speed switch that may be my problem. If so, then I am going to the auto parts store to find a replacement.
Hook'em Last edited by Hook'em; 08-30-2004 at 06:28 PM. |
Back in the sticks
Ya, mine does the same thing and its the switch going bad. Have you noticed the ends of the wires being a little burnt? I still can't figure out why mine does that. Even if I replace the switch, it doesn't take very long before it does it again. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Lovin' Life in Miss.!
I had a very similar problem. Turns out the blower relay has a grounding issue. The ground for the relay uses a ground strap. The ground bolts from the relay mount to a chassis ground. The relay is mounted to the plastic ac case. The relay mounting screw had been over torqued and would no longer keep the ground strap tight enough against the relay to provide a constant ground. I went to a relay with a ground terminal. It has 5 pins instead of 4. Bought it from Kragens. GP Sorensen part # AC11. Your switch looks fine from here. When my switch went out it had plenty of arcing on it. Hope this helps.
Rich
The truck... you hear that? No really, you did hear that?!!! |
