![]() Join Date: Jun 2002
Wtb Under Dash Wiring Harness
I Am Changing From Lites To Gauges And Need A Uncut Wiring Harness For Under The Dash. Thanks,buddy
![]() Join Date: Jul 2001
May be able to help on that one. Am parting out a '71 with gauge dash, think the harness is good with no splices or cuts. Will check when I get home tomorrow from work and let you know. Just the inside under dash portion is what you are needing, correct?
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
I Will Need Everthing To Go From Dash Lites To Gauges. Will Need Under Hood Also. Thanks,buddy
What year and is for auto or stick ? If Ironhorse can't help you i do have an uncut and nice under dash wiring harness for 72 with auto . Jose
Wiring Harness
Hi, Jose It Is A Auto. Thanks,buddy
Pulled the harness from the truck and found only one minor area that has a splice. At the dimmer switch, rather easy fix to re-do. Non-air truck, standard shift 3 on the tree. Under hood harness has been "butchered" and spliced to much. If interested let me know, may want to go with Jose if needing an auto harness.
Wtb
Ironhorse, Thanks ,for Your Help. Buddy
Wtb
Jose, What Do You Have That I Need To Make This Swap ? 350\auto With Lites To Gauges. Thanks,buddy
Not exactly sure but i thought all one has to do is change a few wiring connections on the plug that plugs in to the back of the instrument panel . Using the existing wires on the plug . As for the oil lite you would have to replace the oil sending with a fitting that will allow you to use 1/8 inch copper tubing . Run the tubing to the back of the oil gauge . You might want to post on the 67/72 message board for tips on how to do the conversion .
Wiring Harness
Jose, You Do Have A Uncut Wiring Haress For Gauges. What Are You Asking For It? Thanks,buddy
I bought these from a current member . I was going to use it on a different project but plans do change . The wiring harness is realy nice with no cuts or splices to it . I paid 65 plus shipping for it thats what i want for it . Let me know i can email you a picture of it . Jose
![]() Join Date: Jul 2004
Hey Bestchevyfan
If you can't work a deal with Jose, let me know- I'll check when I get home for cuts and splices, but I "THINK" I have the complete harness- fuse block, engine and interior- don't remember about the rear section/fuel tank/lights,- but also the voltage reg, alternator, a/c wiring, a/c control panel- minus the switches and cables- I swapped my tired 350 for a 454 and a new painless wiring harness.- It was a guage unit- heck, I've even got the old instrument cluster AND a new tach- just needs new glass, printed circuit, new bezel, blah blah blah blah blah. Came out of a 71 Blazer with guages and air. Again, only if it doesn't work out with Jose. |
