ran out of money
center bearings? the best?
Ok so i have blown out my center bearing. I dont feel like going through napa again to get another center bearing. i also was looking for something beefier since i have a built 700r4 in the truck. I was looking into inland empire drivelines center bearing. has anyone used this one? any input will be great
Thanks Rat
Modify everything, leave nothing alone!~ ![]() ![]() |
The oddest Todd around
Why not just eliminate it and go with a one piece drive shaft?
its all about the +6 inches
If you haver a LWB truck and don't want to spend the 500 bucks to get a high quality one piece drive shaft that may or may not 'whip' at high speeds, (esp with an overdrive where the drive shaft goes faster than the crank) then PM NeonLarry and ask him about the carrier bearing he did on his truck. I don't remember the details, but it looked tough as nails and polu instead of rubber ect...he also had to make it fit properly though. He had a whole thread on this and I'm willing to bet he kept a link to it.
ran out of money
yeah its a long bed so i am not about to go buck wild and get a one piece. i just want to find a tough center bearing that can handle my abuse.
Thanks Rat
I put one in my truck after it had gone through two carrier bearings its still in there and doing fine. The only problen I had was I had to machine (narrow) the upper portion where it goes into the frame mount, this has since been fixed. I just installed another one in the Burb along with a newer working tranny. The newer ones go in no problem.
After seeing the difference between the stock bearings and these I would use nothing else.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
ran out of money
thanks everyone! Larry if you dont mind me asking what is the price on these bad boys?
Thanks Rat
IIRC they were about $100.
