Old 09-01-2004, 07:09 PM   #1
dennis111
dennis111's Avatar
Which master cylinder-disc conversion????
I am in the process of converting my 68' to disc brakes. I also wish to replace the original type power brake booster with one from a 3/4 ton. I am confused on which booster to use on my truck.
Should I order a booster for a 68' or one for a 72'? The reason I ask is that there are different ones listed AND I want to be sure it is compatible with my new disc brake master cylinder. I also have heard that the brackets are different between the 2 years--true or false? If so can mine be modded if a 72' booster is needed?
Thanks!
Dennis
68 GMC SWB Custom 1/2 ton, 2WD, 350 V8, PS, PB, 3-Speed, 3:08 12 bolt rear, tilt, tach, vac, cruise and more. . . .
dennis111 is offline   Reply With Quote
Old 09-03-2004, 07:39 AM   #2
dennis111
dennis111's Avatar
ttt
Dennis
Old 09-09-2004, 09:12 AM   #3
dennis111
dennis111's Avatar
Anybody???
Dennis
Old 09-09-2004, 12:55 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
You will want a 71-72 1/2 ton booster/master cylinder and prop valve. You can get them new from board vendors or try a wanted post in the parts section.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
