09-01-2004, 09:39 PM | #1 |
City's Articulation Ramp
FS 69 SWB Body Dropped CHEAP QUICK
I decided to sell my project truck. Have too many projects going at once, enough as where they are a chore compared to a hobby. Anyways, here it is. 1969 Chevy SWB Fleetside C10 2wd. When I bought the truck it was all together, tossed the motor and trans, and started from ground up. Frame was rusted out above the rear coil springs so I built a new rear frame out of 2x5 11ga tubing. The new rear is straight, which ment shimming the trailing arms and welding new perches on the axle. The truck can now comfortable tuck 16-18" slicks. I notched the tubing above the 5 inch drop coil spring to bring it 7" rear suspension drop. The rear is out of a 5 lug truck with 4.10 open. Now to the front, replaced the springs with 2" drop coils and the spindles with 2.5" drop disk spindles. New rotors and calipers and pads too. Moving on to the bed, only thing I have done is cut out the rusted out floor and had a cutout of aluminum sheet metal to install. The front clip is in decent condition, grills dented up, fenders are smooth, but previously restored. The hood is staight, but I had cut two lines in to make my own cowl induction, but never finished. Now the cab, where to begin. The cab has a 4/2.5" modified body drop. I cut out the entire floor then into 3 pieces. The under the seat and tranny tunnel are 4" higher, the area where you feet rest are 2.5" higher. I accomplished this by lowering the front frames mounts down 1.5 inches. I replaced the floorboards, dogleg, passenger side rocker, pass. cab corner, replaced the whole rear cab with a staighter one off another cab, shaved the heater box, repaired rust on the outer side of the firewall and cowl vent areas. I also have replaced the 4 cab mounts but the need to be finish welded in. New bushings and bolts to hold the cab in place. I will include the drivers side cab corner, rocker, dog leg, and custom inner rocker. The doors are in ok condition, I would probaly replace or skin em. No windshield but does have back glass. The dash is out of the truck and I have most the ingination hinges and other small things. I cluster is destroyed. The cab also has some issues of rust in the bottom corners of the windshield down to the floor. Have sections from another cab to help repair. Doors have glass. The title is a clean MIssouri title. I am located in St. Louis Missouri. Any more questions fire away, but I have limited access to the computer so for quicker answers call me at 314-226-6420. DIRT CHEAP FIRMFIRM I have over four thousand invested, plus hundreds and hundreds of hours invested, but understand a project truck ain't worth much. I can either leave the truck apart, bare cab on bare frame, or hang the doors and put the front clip on, the bed needs more work before it is able to be re-fitted. I also have 2 power brake boosters for the truck, the original power drum set up and I believed to be a power disk set up. I also the the column, which was a 3 on the tree.
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy 00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver 06 Harley Sporster 883 low 19?? Zamboni, Really I own a Zamboni! "If your gonna be stupid, then you better be tough." Last edited by Joey-D; 07-31-2005 at 11:36 PM. |
09-01-2004, 09:45 PM | #2 |
more pics
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy 00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver 06 Harley Sporster 883 low 19?? Zamboni, Really I own a Zamboni! "If your gonna be stupid, then you better be tough." |
09-01-2004, 09:53 PM | #3 |
Decided to try here first. If no buyers by, say, Sept 15. I will ebay it.
09-01-2004, 09:57 PM | #4 |
still more
09-01-2004, 09:58 PM | #5 |
one more for now
09-01-2004, 10:01 PM | #6 |
sorry
09-02-2004, 10:35 PM | #7 |
ttt
09-12-2004, 11:14 PM | #8 |
Make me an offer?! Trade for?!
03-17-2005, 12:06 AM | #9 |
ttt
03-17-2005, 03:08 AM | #10 |
What body work still needs to be done on the cab and the bed? Got more pics of the chassis?
Ben 84 C10 Silverado 14 Silverado Z71 |
03-19-2005, 02:24 AM | #11 |
a couple more pieces of sheetmetal, its been a while since I looked at the truck. Drivers rocker, inner rocker and cab corner....have the pieces. The inner foot wheels on each side of the truck need to be fixed, have pieces of another cab for that. More pics comming up.....a lot of these pics are old and from when I first got the truck
03-19-2005, 02:26 AM | #12 |
more
03-19-2005, 02:28 AM | #13 |
even more
03-19-2005, 02:30 AM | #14 |
still more
03-19-2005, 02:33 AM | #15 |
more I tell ya
03-19-2005, 02:35 AM | #16 |
aint done yet
03-19-2005, 02:38 AM | #17 |
keep em comming
03-19-2005, 02:40 AM | #18 |
what to say
03-19-2005, 02:42 AM | #19 |
almost finished
03-19-2005, 02:42 AM | #20 |
last of them
04-07-2005, 11:15 PM | #21 |
ttt or Trade For.....
04-08-2005, 08:38 AM | #22 |
Drop Parts
Would you be willing to part with the 2'' front drop springs and the 5'' rear drop springs ( I think that is the way I understood it) Also lin close to St. louis so I could easily pick the pieces up.
Also would be interested in one of the power brake boosters thanks
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
04-09-2005, 04:32 AM | #23 |
not ready to part her out yet
06-17-2005, 05:16 PM | #24 |
06-17-2005, 05:52 PM | #25 |
Keepin an eye out
Too bad you have to let it go. I was watching this one w/ interest. Looks like you put alot of time in it..
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
