Old 09-01-2004, 10:59 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Electric fuel pump Q
I know with a carb you want to keep the fuel under 7 PSI....but is 2 1/2 to 4 PSI a bit low for a stock engine over 400 cubes? (No GPM rateing)
Old 09-01-2004, 11:08 PM   #2
fast71
Drive it like U stole it
fast71's Avatar
Andy thats alittle low . needs to be around 5 or 6.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 09-02-2004, 07:50 PM   #3
Longhorn Man
That's what I was thinking...thanks.
Old 09-02-2004, 07:59 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The 2 1/2 to 4 makes me happy. Every spec I've ever remember reading said under 5 psi max. Edelbrock/ Carter carbs are picky abut too high pressure anyway.
Old 09-02-2004, 08:07 PM   #5
Longhorn Man
Hmmm....I would like to buy this pump..it is dirt cheap, readily avalible, and supposed to be quiet too.
Anyone wanna break the tie?
I'm not gonna be racing, but I'll be honest, I kinda dog my vehicles a little bit. This is for the 425 Cad motor, and right now it has a quadra jet, but will probably end up with a 750 edelbrock on top.
Old 09-02-2004, 11:24 PM   #6
cableguy0
andy generally lower pressure means lower volume as well as far as being able to flow enough to keep up with that big block. i would stick with a mechanical pump then upgrade with a good electric later on. that is if the mechanical isnt up to the task which it should be
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-03-2004, 02:03 AM   #7
Alexis
Member since 2000
Alexis's Avatar
I've been told to stay under 7 by all means. i got a summit pump with a regulator. Haven't hook it up yet still got more things to do on the list. Good luck and what is up with the longhorn?
Alexis is offline   Reply With Quote
Old 09-03-2004, 02:38 AM   #8
Longhorn Man
I was going to stay with the mechanical pump...honestly, I hate electric ones. However, the Caddy fuel pumps all have a port for a fuel return line, and my truck does not have this. I did the 'bolt in the return line' trick, but the pump started leaking. I grabbed another pump. and the exact same thing happened. I'm asuming this is becouse of the blocked off return line.
I was thinking about the flow rate, and true, it does generally go down with pressure...and this pump seems pretty low. (I was going to run it on a relay so it would be up near 4 psi all the time)
I guess I'll look for another well priced easily found unit.
Old 09-03-2004, 09:34 AM   #9
Russell
Professional Grade
Russell's Avatar
I picked up a 200 PSI @ 43 GPM for about 130 bucks US + shipping. The guy who sells them says he has been using one on his TPI V8 S-10 for a couple years now with no problem. Says they are real noisy though
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-03-2004, 02:23 PM   #10
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Andy, Try plumbing the return line back into the inlet of the pump between the tank and the inlet filter. As long as you don't have an inlet check valve in the system between the tank and where you plumb it in...it should work fine.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
