Old 09-02-2004, 10:21 AM   #1
1968GMC
love my truck
1968GMC's Avatar
serpentime belt set up Question
I know I need a water pump for this set up but someone told me l need an alternator also. Is this true?
1968GMC is offline   Reply With Quote
Old 09-02-2004, 10:59 AM   #2
neonlarry
neonlarry's Avatar
yup, and a p/s pump, and a fan, all the pulleys, etc. Pretty much everything from the donor vehicle. A/c delete pulleys are really hard to find if you arent going to run a/c in your truck too.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-02-2004, 11:40 AM   #3
MIKE'67
You will need a reverse flow water pump as the serpentine system causes the pump to run the opposite way. Your local NAPA parts delaer can help you out with this.
1977 Short Stepside, black, 350/350. Located in Albertville, Alabama.
MIKE'67 is offline   Reply With Quote
Old 09-02-2004, 07:49 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And make sure to remember what the parts came off of, that way when you get replacement parts...say a water pump, you just tell them it is off a 92 S-10 blazer with the 4.3....or what ever you pull it all off of.
Old 09-02-2004, 09:31 PM   #5
kwmech
Does not matter which way an alternator spins, or mounts. You will need the correct pulley though which can be swapped onto your alternator, but now would be the time to upgrade to an internal reg if you haven't already.
Old 09-03-2004, 12:02 AM   #6
neonlarry
neonlarry's Avatar
The old alternators dont really fit into the new brackets... Its way eaiser to get one off of the truck or car the other stuff comes off of. If you are lucky you can even find the bracket that fits the cs144 alternator.
