Garage Queen Material
going racing tonight
i'm gonna go to the track tonight with a friend.
any bets on what i will run this time??? i'm hoping for mid/high-14's |
paper or plastic?
with the motor listed in your sig I would hope you'd run at least a high 13
good luck tonight ![]()
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
#3 | |
#4 | |
-90 454ss http://www.imagestation.com/album/?id=4289115843 -04 TRX450R -77 c-10 http://www.imagestation.com/album/?id=4290506213 SOLD -82 c-10 SOLD -02 CRF450 SOLD |
#5 | |
paper or plastic?
yeller
Don't show your face around here again unless you run 14.7 or better.
![]() Just for comparisons sake Eric. When Yeller was small block powered, it ran a best of 14.6 @ 92mph. This was a 350 block bored .030 over to 355. Stock 882 cast iron heads with Crane roller rockers, Edelbrock performer RPM intake, Crane cam, Holley carb, headers, shift kit & 2200 stall converter, and 4.10 gears. Basically it was a stock block with cheap bolt on upgrades done in stages. Had I had a couple more runs, it would have run even better (we were playing with timing, jets, springs, etc) If you are concerned with going fast, your first two priorities should be tires and gears...then go from there.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 09-02-2004 at 06:55 PM. |
atleast i have a friend to race tonight!!!
its a civic....... but he just swapped in a new engine so he might beat me badly........ or not |
Project92 SWB stepside
If you get bet by a CIVIC please dont tell us!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
yeller
I bet the Civic has better gears!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
i killed the civic. but all those damn srt-4s killed me
![]() best race: rt: .451 60': 2.412 1/8: 9.872 mph: 74.97 1/4: 15.094 mph: 94.15 the best my friend ran in his civic was 16.4 |
Not bad. Your 60ft time is bad with that open rear though. Although, even with my truck that has a spool I ran a 2.4 60ft on crappy street tires and crappy track. I put my slicks on for the next run and turned 1.9 60ft (still on crappy track cond) Big difference in E.T. though!
86 C-10 SWB 2wd -355/TH350, 3:73's (Vin# says its a V6) ![]() Best ET: 13.0 @ 101mph (NA) 11.9 @ 108mph (100 shot) 02 Chevy 2500HD DMax (tow vehicle) 84 GMC Sierra 2500 00 Formula M6 hardtop |
#12 | |
.03 RT 1.72 60 ft 7.7 660 ft 12.28 1320 ft 110 mph.
11.98 @112mph Stock suspension and little tires. |
#13 |
81 shavedtrk was that 12.28 @ 110 mph on the bottle or all engine?
#14 |
BeWarE tHe eViL CrAnkTOe!
Hmmmm.... I really figured you would have done better than that. Not a bad MPH but figured a lil more.
![]() At least you had fun though.
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
#15 |
i just changed out the bushing in the dizzy a minute ago.
i'm using the blue bushing(21 degrees) with the light blue and light silver springs. all in by around 2800 rpms. last night i was running the silver bushing(25 degrees) and the same springs. it was pinging slightly when i ran the 15.09et with the initial timing at around 14 degrees. i set the timing back to 15 initial with the new bushing and it isnt pinging anymore and seems to run about the same. |
#16 |
You mean to tell me my iron headed 355 with redneck ingeniuty Runs better than that high dollar holley setup?
#17 | |
11.98 @112mph Stock suspension and little tires. Last edited by 81shavedtrk; 09-03-2004 at 09:15 PM. |
#18 |
pretty good man. if you swap to 3.73's from 2.73's it will feel like your spraying 100 shot compared to what it was before. should put you low 14's.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#19 | |
#20 | |
i know my tires are gonna be a huge part in that though |
#21 |
Get some modifed Tires They run well and hook decent on a pair of 8" wheels Ive got a pair mounted up with screws and tubes on some old wagon wheels painted black They get soft if you get a fresh pair
#22 | |
#23 | |
yeller
![]() ![]() ![]() ![]() Trap speed won't win you a race, low ET's will! The boy needs GEARS. The only place I would be "racing" with 2.73's is Bonneville! ![]() ![]()
#24 |
Tonawanda 454
as most of my racing is done on the street versus all these crappy little rice burners and whatever else comes along, theres no clocks or stopwatches from a stoplight, just gas and go.
I had to take down my rearview mirror because im getting sick of seeing so many so far behind me. :LOL: (actually the heat made it fall off lol)
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! ![]() 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
#25 | |
