Old 09-02-2004, 09:35 PM   #1
Chevyguy111786
Kill Switch
I have a 78 that i'm gonna install a kill switch on for security. Which wire should i put this on. i would like it to be in the cab somewhere. What kinda of switch should i get, amps? fuse? let me know what yall got.
Chevyguy111786 is offline   Reply With Quote
Old 09-02-2004, 11:03 PM   #2
dinnut
dinnut's Avatar
i went to walmart and got a basic toggle switch... i wired it in with the power wire going to the hei. my hei power cable is run separately so if they hotwire the truck and the killswitch is activated the starter will spin over for a while but after that they got nothing. i like how mine is setup... i just need to hide it now. autozone and oreilly have all kinds of a neat looking switches.. i had already run an inline fuse for the hei power cable and i think i was using some big power cable...
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 09-02-2004, 11:05 PM   #3
Chevyguy111786
i was thinking the hei power wire too...any others?
Old 09-02-2004, 11:07 PM   #4
dinnut
dinnut's Avatar
you could probably run one to disable the starter...
70 longbed
496/th400/Ford 9"
Old 09-02-2004, 11:08 PM   #5
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
there is the power wire to your ignition, or the purple wire that goes to the starter. not sure if anyone has switched those
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 09-03-2004, 05:05 AM   #6
Lippyp
English Chevy Owner
Lippyp's Avatar
If you've got an electric fuel pump switch the feed to that.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
