09-02-2004, 11:28 PM | #1 |
Engine Building
Well after some consideration I have decided that I want to build a stock 327 for my 68. Minus getting the block, heads, pistons etc sent to a machine shop and magnafluxed, honed etc would this be something that someone who has never built an engine be able to do?
Thanks |
09-03-2004, 12:01 AM | #2 |
What automotive work have you done, valve regrind, replaced intake manifold?
Larry 68 C20 327/465 daily driver 63 C20 292/420 Camper truck 65 C10 ? /powerglide Custom Cab AC,PB,PS,$flashe 70 C10 250/3spd org/Gauge dash,Wood bed 4Sale$1300 |
09-03-2004, 12:08 AM | #3 |
Intake manifold , changed form long to short waterpump, hei distributor, new tranny valve body and vac modulator.
09-03-2004, 12:28 AM | #4 |
You might have a chance. Got the factory shop manual, or a good Glenns or Chiltons, and somebody to call if you run into something your not sure about.
Larry 68 C20 327/465 daily driver 63 C20 292/420 Camper truck 65 C10 ? /powerglide Custom Cab AC,PB,PS,$flashe 70 C10 250/3spd org/Gauge dash,Wood bed, 4Sale$1300 |
09-03-2004, 12:34 AM | #5 |
I'd say yes skokie, it would be a great learning experience. If you run into something your unsure of (even small) just be sure to get experienced advice/help. Some of my friends are wicked smart engine builders with great attitudes (helps alot) and of course this board is a great resource for info as well. Doug
09-03-2004, 12:36 AM | #6 |
I have the factory shop manual and the assembly manuals. Is there any special tools I will need?
09-03-2004, 07:14 AM | #7 |
Watch out for your cornhole !
Torque wrench
taps and dies ring compressor valve spring compressor engine stand hoist air compressor with blow gun I'm sure there's more that I'm not thinking of. Have you considered a Goodwrench 350,4 bolt main,crate engine with 50k mile warranty for 1200 bucks? Then, you can look people right in the eye and tell them it's a 327, they'll never know any difference. All your stuff will bolt right on it and it will look like a 327 from the outside.
09-03-2004, 11:33 AM | #8 |
Yep I have thought of that but and this may sound crazy. I would know that its not a 327. Also I have never done this sort of thing and I think it would be a good way to learn also I have a excuse to go buy more toys (tools).
09-03-2004, 01:59 PM | #9 |
Saving 1 truck at a time!
Perfect reason!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
09-03-2004, 02:05 PM | #10 |
two big differences in the Gm goodwrench 350 and a real 327. One and a very major giveaway would be the center bolt valve covers. Also when you mash the pedal. A 350 runs out of steam sooner than a short stoke 327. Go for the 327, it will be alot of fun building it and also be a little different than all the other trucks you will run across.
All this coming from a guy who really likes the old 327. So I am biased.
-- Will Evans -- 1955 Short Step "Sweet Pea" - Family heirloom. 1969 Suburban "Otis" - 396/TH400 - Dallas Ambulance - 1972 K5 blazer "Rusty" - 400/TH350/NP205 - Yeah it's big alright!! - Founding Member of Southern Bowties Club - |
09-03-2004, 04:17 PM | #11 | |
Just my opinion. Rick H... You can stil ldo the assmebly.
Rick H.... 69 C10-CST Wood bed floor full power 70 SWB 425hp HOTROD! Full power 71 C20 Camper Special 402 full power, factory dual tanks with gauge switch. FOR SALE! |
09-03-2004, 04:18 PM | #12 |
I was going to build my 327 with the help of a machinist neighbor friend. The neighbor friend never had time to help me. I chickened out and ran out of time so I had my machine shop assemble it for me. I have no regrets but it did cost some more in the end. Do you have a good shop to work in? That was one of my problems too.
If it were me I'd find a tired beater 350 and at least tear it down/play with it and get familiar with things before I tore into a good 327.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
09-03-2004, 04:30 PM | #13 |
I may have the machine shop do the lower ends but I will request to watch them do it if that is possible. If not then there has to be a book out there somewhere that you can buy that will show you how to do this. As far as space goes If I clean my garage out I can get a space thats about 10 ft / 8 ft Maybe even more. Plus I have some shelves that I am not using that I could use for storage of the parts until I can install them.
09-03-2004, 04:31 PM | #14 |
Just thought of something here. What kind of pistons are in a stock 327?
Thanks |
09-03-2004, 05:55 PM | #15 |
SMOKIE 55-
The 1200 dollar 4 bolt Goodwrench engine uses the same old fashioned 4 perimeter bolt valve covers as every other small block built from 1957 through 1986.
09-03-2004, 06:12 PM | #16 |
A classic GM kinda guy
That book that may help you is "Build the Smallblock Chevy", found at most bookstores in the Automotive section (at least where I live).
Old school rap music: a dual exhausted GM 6 with no mufflers. "If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s. "I did. They are called Classic GM pickups !!!" |
09-03-2004, 06:38 PM | #17 |
09-03-2004, 07:04 PM | #18 |
Got Light Emitting Diode?
i think a shop would let you watch. maybe not on the machining part but you should be able to set up a time to help/watch them assemble it. the most fun i had with my motor was the heads. i borrowed a spring compressor and took them apart and removed all of the burrs and hogged them out alittle. all of the valve seats looked real good except the one i nicked when porting but the local head shop did a 3 angle valve grind on that one seat for free, guess i got lucky
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
09-03-2004, 07:12 PM | #19 |
Never use a ridge cutter on an engine block maybe a briggs and stratton but not a car engine.
I suggest getting a book called building the small block chevy by david vizard There are a few things in there that im not too crazy about but otherwise is a very good book with plenty of illustrations and good procedures . http://www.angeleentshirt.com/chevy_engine.htm |
09-03-2004, 11:16 PM | #20 | |
I have rebuilt lots of engines in the last 25 or so years, and have used a ridge reamer quite a bit without any problems. In my expirience you can't hone a ridge away, and unless you are gonna punch it out the ridge has to go away somehow. Dan |
09-04-2004, 08:59 AM | #21 |
The book recommended by 1972C10 is an excellent reference "How to rebuild your Small Block Chevy". It has a short history of the sbc and contains a list of head and block casting numbers too... Rebuilding from start to finish, including break-in.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
09-04-2004, 10:47 AM | #22 |
I would definetly re-build the 327!! don't let that great motor go to waste. A 327 will out run a 350 any day, keep it.
Man I need another 67-72!!! |
09-04-2004, 12:30 PM | #23 |
I Dont Belive in ridge reaming If the cylinder is worn that much why waste money rigging it up do it right get it bored have a fresh cylinder , Ive always been told that ridge reamers ruin a block also.
09-04-2004, 12:52 PM | #24 | |
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 09-04-2004 at 01:00 PM. |
09-04-2004, 01:10 PM | #25 |
JB-80 "Twice as Good"
skokie- I agree,the book by David Vizard called "how to rebuild your small block chevy" is very good........walks you through what you need to know! Also,I've used a ridge reamer when disassembling motors with no trouble at all.
HEY NOW! |
