Old 09-04-2004, 02:28 AM   #1
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Angry Bent hood?
I have a very bad bend in my hood, about half way back towards the edges. Most of the yards around here have hoods with the exact same bend, just not as bad. What causes this and how can it stop it from happening to a brand new hood? Thanks
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 09-04-2004, 02:39 AM   #2
Russell
Professional Grade
Russell's Avatar
That'd be caused by a lack of hood spring hinge maintenance... To prevent it, keep your hood spring hinges well oiled. There are also aftermarket hood reinforcement kits you can buy and install.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-04-2004, 02:46 AM   #3
Justins76
Justins76's Avatar
Post
I've got some metal reinforcements on the underside of the hood, but its just secured into the sheet metal. Doesn't seem to really do anything. Is there a lower tension spring available?
My cardomain page
Old 09-04-2004, 08:14 AM   #4
76bonanza
76bonanza's Avatar
It is the hinges that need oiling. Has very little to do with the springs. The hinges get to were they are hard to close then you pull hard on the hood and then it bends. The braces will help it from getting worse but not fix it.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 09-04-2004, 10:28 AM   #5
RockHQ
ROCKET POWER!
RockHQ's Avatar
When the hinges wear out, they start to bind, which can happen regardless of how well they're lubed. The trick is to push the hood towards the cab when closing it to get the hinges moving. Yeah, mine is bent too, compliments of a previous owner.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 09-04-2004, 12:21 PM   #6
78SilveradoSWB
78SilveradoSWB's Avatar
I think its also in the design of the hood. I read in some other post that the GM engineers designed the hood to crease to protect passengers in a front end collision which makes the hood prone to crease with hinge problems too.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 09-04-2004, 12:36 PM   #7
cliffsta
Stepsides RULE
cliffsta's Avatar
corrrect. in 77 i believe, GM designed the hoods to curl in a collision to protect the passengers, so basically they just weakened the hood. I know, since i got a bent hood.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 09-04-2004, 02:12 PM   #8
Greenlee
Greenlee's Avatar
Yep. I bought a new hood and have oiled the crap out of the hinges, and it still looks like its binding a bit. I'm really careful when I close the hood. I get real paranoid when someone else tries to close it. To add insult to injury, the reproduction hood I bought is probably thinner than the original.
Greenlee is offline   Reply With Quote
Old 09-04-2004, 07:25 PM   #9
cliffsta
Stepsides RULE
cliffsta's Avatar
yeah im planning a trip to the salvage yard soon, 2 things im looking for: decent hood and bedsides. From what i've gathered, reproduction pieces, while cheap, are a good deal thinner that OE, which makes them *cheasy*
Old 09-04-2004, 07:42 PM   #10
81shavedtrk
Take springs off and use a prop rod.
11.98 @112mph Stock suspension and little tires.
81shavedtrk is offline   Reply With Quote
Old 09-04-2004, 08:46 PM   #11
swervin ervin
You get what you pay for
swervin ervin's Avatar
Now, all you guys who bad mouthed the 81+ frontends in another thread are getting paid back. The 81+ frontends don't have this problem.
Although, after saying the above, I really do hate to hear your hood is bending. I don't like to see any of my 73-87 brothers/sisters having problems with their rides and I sure want say anything bad about what they have.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-04-2004, 09:59 PM   #12
SanitysBane
just push it back towards the cab and go side to side with it, we did that with our 77, never had a problem, and also on dads 70 chevelle, no problem their ether
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 09-04-2004, 10:04 PM   #13
screwballl
Tonawanda 454
screwballl's Avatar
no problems here with my 76, the hinges may look a bit rough from age but theymove just as theyre supposed to, nice and loose..
hate to hear someone else having that problem, might as well go get new hinges and oil the heck out of them
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 09-04-2004, 10:08 PM   #14
Greenlee
Greenlee's Avatar
Good luck finding an orignal hood that isn't bent already. I hardly ever see them around here. My original hood wasn't bent. I thought it was salvabable, but when I started sanding off the surface rust it turned out to be rusted almost all the way through in a couple of spots.
Old 09-05-2004, 12:07 PM   #15
cliffsta
Stepsides RULE
cliffsta's Avatar
well then do yall reckon i could bend it like beckom and maybe get it close to fitting better? my dad has offered to try and bend it back, but would that work? Just get a couple 2x4s and a hammer?
