where to buy my weatherstrip
Looking at chevy duty, where did some of you guy's buy yours. Need it all, doors,windshield,backglass. Any tricks on install would be helpful.
Designated A-hole!
check the vendors on the left side of the www.67-72chevytrucks.com page. They have good prices and support the board. Most of them are board members.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Designated A-hole!
Have also heard of people using s-10 door weather stripping. If I find the info I will post it 4 u.
1969 Custom 30 wrecker
I got my door and window weather strips from Chevy duty and they are still going strong. Just stay away from the gas tank filler grommets. They are total junk!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Who me?
I used the weather striping from a new S10 blazer, It works great. It's a little long which is nice so you can mould it to the opening and cut off the rest. Got them from junk yard for $10!
Living the dream ![]() 72 2WD Blazer, under going porter built surgery 67 GT Mustang fastback 67 Mustang coupe C/S clone 64 Falcon sprint hardtop |
When you go to install the door w-stripping make sure it's clean and free of the talc used in the molding process or it'll come loose sooner or later.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
It has been a while since I got mine but I think I got em from tim christian???
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Merciless Butcher
I am sold on Soffseal. They offer the best IMO. Here's a link..Check it out. http://www.soffseal.com/
Your Bought And Sold....I Got Your Soul! |
![]() Join Date: Dec 1999
I am a Soffseal dealer now and I do have to admit it is very nice but it is high in price. If I can help you with the soffseal or other let me know. Thanks Tim
Merciless Butcher
That's great Tim....Now I know who I will buy my soffseal weatherstrip from in the future.
Thanks guys, I didn't know about the s10 weatherstrip working on our trucks.
Active Member
![]() Join Date: Feb 2000
My 68
Obsessive is right, The s-10 blazer weatherstrip is much better and if you look at the two side by side, you you will see the difference right away. Hard to explain, but the Blazer type is thicker on the soft rubber part( that seals against the door) and it has a metal piece molded in that fits on the channel on your cab.It really helps with wind noise. Carl71(?) put it on his truck and GMC Paul has it in his catalog. I got mine at the Chevy dealer(very pricey). I'm sure other board vendors have it( cheaper too). I think you'll really like it. Good luck!
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
#13 |
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
#14 |
Active Member
I meant 71Chev. Carl 71........ hmmm. My clutch must be slippin'!
