09-04-2004, 10:28 AM | #1 |
Help with correct auto-tilt column and 700R4 tranny
I have purchased a 700R4 tranny to install in my completely out of control 71' restoration. It seems like everything that I told my self I would skip and just get her painted and on the road has gone to the way side. Anyway...I have a new 700R4 trans and now want to purchase the best Auto-tilt column that will work well with the 700R4. Does an OEM auto-tilt work fine? Should I use and IDIDIT? Money is somewhat of an issue but putting in the best auto-tilt for the 700R4 might be more important to me. Just looking for some help here and maybe some of you guys that already have the 700R4 in place can chime in. Thanks in advance to all the great people here!!!
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 09-04-2004 at 10:40 AM. Reason: spelling |
09-04-2004, 10:55 AM | #2 |
Any steering column will work, try to find a factory auto tilt if you want, or the van tilts can be retrofited. If you have deep pockets, a billit tilt looks real cool.
09-04-2004, 01:58 PM | #3 |
I still want to see pic's of A newer tilt with the key on the column. To go with A 700R4.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
09-04-2004, 02:04 PM | #4 |
Car Knocker
I just adjusted my stock column where it is in park. All other gears are correct. Just can't get to low 1. Well I can, it is just off the indicator.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
09-04-2004, 02:18 PM | #5 |
So It sounds like a stock one will work fine...but the indicator is off the map when you shift into Low 1? I do want an Auto-Tilt but may explore the billit options??? Where's the best place to look at these? Ididit??? Thanks Guys!
Alex 1971 Lil' Red 350 SBC 700R4 |
09-04-2004, 02:30 PM | #6 |
ididit.com has a indicator for on the column for a 700r4
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
09-04-2004, 03:04 PM | #7 |
If I remember right I bought the IDIDIT indicator on my 700 save your money. Didn't line up. Furthermore who ever uses 1 st gear anyway?
Smitty '71 Short Fleetside Spring Valley, Ca. |
09-04-2004, 08:05 PM | #8 |
So are you saying just get an original Auto-tilt???
09-05-2004, 12:25 AM | #9 |
its all about the +6 inches
wopuld..I agree with smitty...I don't think I have ever placed my shifter in first....at least, i never NEEDED to.
you thought about a Hurst shifter or something like that on the floor? |
09-05-2004, 11:43 AM | #10 |
Hey Chevy Dude when my brother built his '71 he just bought a rebuilt truck tilt column from someone in No. Cal. worked great. Probably has less invested than I do having mine rebuillt etc. I didn't learn the first time when I bought the lens from IDIDIT and later bought another from the Truck Shop, they look nice but are irrelavent because they don't coincide with the shifting detents. I have a lens from a 350-400 trans I'm going to throw in next. I think it goes Park-Rev-Neut-Drive-L1-L2. I think it will line up with the shifting detents and am not going to worry about the unused 1st gear. I'll talk to the bro. later and find out where he bought the column from and maybe this will give you another option. Try to get this info to you later today.
09-05-2004, 01:37 PM | #11 |
I bought an auto tilt out of 70's model van. I then bought the Ididit 700R4 indicator. You will have to do some modifications to install it in the factory indicator housing, but if done right, it looks original. My truck was previously a manual truck, so I had to make the linkage to connect the column to the trans. I just made it adjustable, so once I adjusted it, all the gear line up with the indicator. You can also purchase a similar linkage kit through several street rod companies.
09-05-2004, 03:56 PM | #12 |
Thanks Guys!!!
09-05-2004, 07:44 PM | #13 |
Bro bought his tilt from Early Classic Enterprises in Fresno, Ca. for what it's worth!
