Old 09-04-2004, 10:54 AM   #1
bgunther
Removing Ball Joints
Can I grind the rivots off to remove the ball joints on the control arms since i will be replacing them?
67 GMC LB (all in parts for now)
bgunther is offline   Reply With Quote
Old 09-04-2004, 12:20 PM   #2
Sweet72
Sweet72's Avatar
Grind off, drill off or chisel them off and drive them out with a pin punch.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 09-04-2004, 01:30 PM   #3
s95930
A-Adam A-Adam
s95930's Avatar
Just did my uppers. Drill a 1/4 in hole in them and the hit them with a good sharp chisel. The head will pop off then drive the rest of the rivot out with a punch
70 3/4 ton GMC Camper Special
s95930 is offline   Reply With Quote
Old 09-04-2004, 05:30 PM   #4
bgunther
Uppers were easy, any help with the lowers?
Old 09-04-2004, 07:09 PM   #5
neonlarry
neonlarry's Avatar
I use a press but you can rent a tool for free from AZ that will remove and install.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-04-2004, 11:53 PM   #6
Warbones
Navel Inspector
Warbones's Avatar
I want to make sure. AZ = Auto Zone?
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 09-05-2004, 01:55 AM   #7
lock
Insert funny comment.
lock's Avatar
Yup, can't beat their rental tool deal! (unless ytou break something like I did once)
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 09-05-2004, 02:56 AM   #8
stllookn
Saving 1 truck at a time!
stllookn's Avatar
The lower ball joint requires a press to get it out of the lower arm and a press to put the new one back in place. Unless you have access to one you are going to have to get an auto machine shop to help you.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
