Old 09-04-2004, 12:40 PM   #1
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Name that interior noise
Okay I think I have an idea on what it is but I need to ask if anyone can pinpoint it exactly. When I'm driving down the road just after going say a few miles down the road (few being less than 10) I'll hear a squealing creaking inside the cab under and behind the dash. It's only for about 20-30 seconds but it's noisy as hell until it stops.
Now I'm thinking it's something to do with a vent inside the cab because it only happens at different times. When I'm driving at night it doesn't do it as soon. When I'm driving in the day when I first start off in a couple minutes it starts up. I think it has something to do with the temperature outside to activate the vent. Am I thinking right and if so where is it and how to "grease it"?
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 09-04-2004, 12:54 PM   #2
cliffsta
Stepsides RULE
cliffsta's Avatar
hmmm just throwing something out there; my aunt's ford taurus makes a whining noise when there's a crosswind because a seal on the vent is bad or something like that. Kinda sounds like that maybe, or maybe not. Just tryin to throw something out for ya.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 09-04-2004, 02:13 PM   #3
79BIG10
79BIG10's Avatar
Good idea but no cross wind to get where this noise is coming from. It's definately a vent of some kind that's opening but I can't find out where.
Old 09-04-2004, 10:38 PM   #4
plumbcut
california fill
are you sure its not the fan? my fan makes one hell of a noise, dirty old thing.
pc
plumbcut is offline   Reply With Quote
Old 09-04-2004, 10:41 PM   #5
screwballl
Tonawanda 454
screwballl's Avatar
nasty dirty fan motors can make a helluva racket, sometimes at specific temperatures. i replaced mine and now no sound at all (because the switch in the dash is screwed)
:LOL:
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 09-04-2004, 11:27 PM   #6
SanitysBane
could be the speedo cable, mine did that till i greased it up
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 09-05-2004, 12:37 AM   #7
79BIG10
79BIG10's Avatar
PC- Good idea. It might be that. Doesn't it run when the ignition is on? If so time for a new one and maybe a better one.
SB- I've replaced the speedo cable with a new one with my Autometer gauge swap. Also it doesn't do it only when driving and it's coming from near the middle and passenger side behind the dash.
Old 09-05-2004, 12:44 AM   #8
swervin ervin
You get what you pay for
swervin ervin's Avatar
Brandon,
I bet money it's your fan. They do run on low speed all the time (I think). Even if it didn't, I'm guessing with the air going through the vent, it may start it spinning and when it slows down, the bearing is gone and it squeals like a rat with his tail in a trap.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-05-2004, 12:47 AM   #9
79BIG10
79BIG10's Avatar
That's the sound Mike Now does anyone know where I can get one that works better (more CFM) than factory? The one I have is awful.
Old 09-05-2004, 07:03 AM   #10
Nvbowtie
Nvbowtie's Avatar
Unplug the fan motor, and see what happens
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 09-05-2004, 12:50 PM   #11
79BIG10
79BIG10's Avatar
Well I just replced the blower motor and works same as the other one but no sound so far. I'll drive it later today to see my "friend" and see if we hear it then.
Old 09-05-2004, 01:10 PM   #12
plumbcut
california fill
brandon- I bet if you fixed up the HVAC vacuum system, and checked all the door closers and stuff, it would make the fan seem like it works a lot better..
my recommendation- goto the big black ball thing in the engine compartment, which is the vacuum reservoir for the door movers, and unhook the vacuum line that goes from it, to the intake manifold tee.. unhook it at the Tee side, and connect a vacuum pump w/ guage to it and create a vacuum... see if it holds it, i bet it doesnt.. it shouldnt leak down within several minutes. if it DOES- you've found a huge problem in the system.. then you gotta investigate and find out why & where.. with a vacuum in the system, go move the selector to MAX AC, vent, defrost, etc and listen for the doors moving (engine OFF for queitness).. if the system is working correctly you should get a LOT of wind thru the front dash vents on max AC (fan high)...
Im willing to bet you dont even have the vacuum line from the engine to the black ball, what with your motor swap and all.. let us know! trust me you'll be amazed at what a difference the working system makes. (I was.)
pc
Old 09-05-2004, 01:18 PM   #13
79BIG10
79BIG10's Avatar
I'll try that but I do have the ball hooked up. I did have that hooked up and I'll check it later with the gauge. I can hear the doors open up and close as need be. On the amount of not flowing out I don't have the vent "deflectors" in the dash or the bezel right now so I know it's flowing more than it should out the passenger side and also I need to reinstall the lower AC duct as well. Once i have all those that might help out as well
Old 09-05-2004, 05:27 PM   #14
1FaastC10
1FaastC10's Avatar
i think your truck is just haunted.
1FaastC10 is offline   Reply With Quote
Old 09-05-2004, 07:17 PM   #15
swervin ervin
Every man needs "friends" like that.
Of course my wife probably wouldn't agree with me.
