Old 09-04-2004, 02:55 PM   #1
rn2fine
rn2fine's Avatar
Rear Brake Line, Need One, is Burb Same as Truck
I have a 2wd C10 72 Burb with a 12 bolt rear. When I changed wheel cylinders on the rear brakes I messed up the passenger side rear brake line. It is a steel brake line that goes from just above the differential to the passenger side rear wheel cylinder (drum brakes). Need a new one. Does anyone know where I can get a new pre-made brake line. Ricks, Impala Bobs, or etc...??? Also, is it the same as the brake line for a truck of the same year with the 12 bolt rear?
Thanks,
Jeff
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 09-04-2004, 04:29 PM   #2
Sweet72
Sweet72's Avatar
You have options. If you don't care about the spring stone guards like the orig. line had, you can bend a pre-cut and flared line of the same length from a auto parts store, and bend it yourself (done that when in a similar situation... or you can order one from one of the vendors listed on the opening page of this board. I bought my lines from here www.rightstuffdetailing.com
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 09-04-2004, 05:00 PM   #3
LONGHAIR
I know several of the guys at "The Right Stuff" and I can tell you that their parts are top quality and the service excellent.
LONGHAIR is offline   Reply With Quote
Old 09-04-2004, 06:08 PM   #4
rn2fine
rn2fine's Avatar
I checked out the link that you guys sent me and the company looks like they do great work. Their web-site catalog however does not show truck applications or applications for a 1972. I am going to call them on Tuesday. I did find a company that sells a rear passenger side axle brake line for a 72 C10 Pickup. If anyone out there has a 72 C10 pickup with a 12 bolt rear could you take a digital picture of the passenger rear axle brake line that goes from just above the differential to the wheel cylinder. I want to see if it is the same as my Suburban.
Thanks,
Jeff
68 Chevelle
Old 09-04-2004, 06:14 PM   #5
neonlarry
neonlarry's Avatar
I have a 70 truck & 71 Burb and they are the same.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-05-2004, 12:25 AM   #6
rn2fine
rn2fine's Avatar
Thanks Neon. I appreciate you checking it out for me.
Jeff
68 Chevelle
