09-04-2004, 08:17 PM | #1 |
Which transmission?
I know most of us here have autos but I'm lookin to put in an overdrive of some sort. I know a 2004r will pretty much slide right in where my 350th is now so that is a real possibility...seems like most of us are going to 700r4s so has anyone got any advice on the 2004r?
I'd really like to put in a manual 5 speed but all I get from the local salvage yards is that "chevy just hasn't made a reliable 5 speed"...anyone here know better? Let me have some feedback, I'm wanting to adjust my cruising rpms and would rather not change my 3.73 rearend. thanks,
1967 C10 Short,Step 283\1460 Holley HEI Ign. Borg Warner T56 6 Speed! A-1 Electric life pwr windows PS,PB,Tilt 275\60R'S on Alum Mags all around Vintage Air A\C Grey cloth Buckets |
09-04-2004, 08:32 PM | #2 |
the NV4500 is a reliable 5-speed from what I've seen, but expensive to say the least. Most of the 4-speeds can hold up to abuse but then you don't get an overdrive (unless you find one of the obscure 4-spd overdrives chevy made in the 80's [and good luck finding parts for it if you break something]). Most of the trannys put in the S-10's aren't enough to put up with a stock, much less modified 350, this includes the NV3500 (with integral bellhousing) and T5, I know some people have run these on this board without problems but if you like to bang gears its not an especially good idea. I struggled with the same debate in my '72 and now that its out of commission I'm thinking about how much I'd love to have a 5 speed in my '83 K5, which is a 4WD.
Also if you're looking at dropping an overdrive into a 2WD you have much more varied options from some of the passenger cars, including the T56 6-speed found in camaros, firebirds and vette's, 4+3 found in corvettes, and ZF found in corvettes. Unfortunately none of these options will be cheap |
09-04-2004, 08:56 PM | #3 |
The toplading shifter will be in the bench seat with a t-5 so in goes buckets and even then the shifter seems like to me it would be too far back.
I've been led to think that the 200 4r is a good choice and can be built to handle lots of power or left stock can hold up pretty well with a mildly modified motor. Thats just my humble opinion. |
09-05-2004, 12:11 AM | #4 |
its all about the +6 inches
The T 5 is pretty much junk. (go ahead and flame me) the strongest STOCK one only holds 305 foot pounds, and that doesn't take into consideration for the added weight of a pig truck or 'spirited' driving.
I'm not sure which tranny Huck used, but he did a kickin conversion in his 71 Chevy with a late model chevy truck 5 speed and he is very happy with it. He did the Hyd clutch, and everything. His only complaint is no speedo. I did fione a solution for that, but it was like a $300 piece...or something just as crazy, and he said no thanks. Personally, if you were to go the automatic route, I say 200 4R. I like the gearing, and the many options in aplications. While they do need work to hold up to gobs of power, they have less internal loss due to friction (acording to the Kilgore rating) than any other GM auto/overdrive. Another option...again, kinda spendy, is a gear vendors (Or other brand) aux tranny....it is an add on unit that you bolt onto the tailshaft of your existing tranny. This is a gear splitter, and you end up with first, first high, second, second high...ect. In the gear splitting, you don't need to hit the clutch pedal, and this makes drag racing a little quicker since you keep the motor in the sweet spot by shifting, but you aren't hurting the rate of acceleration by lifting and clutching. The gear vendors was designed for the RV and straight trucks, and is designed to hold up to 1500 horse motors. Our tranny shop has done quite a few gear vendors installs, and no one ever comnplains about them....except the cost. |
09-05-2004, 10:26 AM | #5 |
Well said, Longhorn Man.
I saw Huck's manual transmission set up when I bought his red 71. It was really nice. Contact "HUCK" for more information. Steve |
09-05-2004, 10:34 AM | #6 |
What cars did the 2004r come in? What a decent price to pay for one? Does the shifter linkage hook right up or would it require modifcation?
09-05-2004, 08:06 PM | #7 |
ttt
1971 LWB Chevy C-10 350/350 3:42 eaton |
09-05-2004, 08:48 PM | #8 | |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
09-06-2004, 06:25 PM | #9 |
Where's the posts?
Fellas, I've scoured the archives in engine and drivetrain, general discussion, and 67-72 trucks and I can't turn up the discussion of Huck's overdrive install...anyone have anymore clues?
thanks!
09-06-2004, 07:48 PM | #10 |
Can you make it to the Ohio Board Meet? He'll be there with that truck. (Yeah, just a plug for our get together)
09-06-2004, 10:01 PM | #11 |
I wish Longhorn, But lack of off time won't let me
I'll bet its gonna be a good time! Ever do a meet in Atlanta area? Or middle Tennessee perhaps?
09-06-2004, 10:08 PM | #12 |
The LuvShack Garage
I Was Thinking Of Huck's Truck Also, Drove It Here, Like 5.5 Hrs...
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
09-06-2004, 10:28 PM | #13 |
I can't remember much of the details...clutch master cylinder mounted on the firewall....moved the brake booster out a fraction of an inch for clerance, a stock hyd line to the slave cylinder...
Like I said, no details. |
09-07-2004, 11:25 AM | #14 |
Young Gun wth Fast Inline
Almost positive that huck has a nv4500 in his truck. They should be plenty of tranny to hold up to any naturally aspirated small block. My friend runs one in a dodge pushing 1000 ft lbs of tire burning power and has only had to do some minor tranny work.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
09-07-2004, 10:37 PM | #15 |
They put those NV4500 behind Dodge Cummins and other big truck engines, so I know they will take the abuse of a 350. You will need to get a bellhousing designed for one though, the input shaft retainer diameter is different than most Chevy car and truck versions. I believe the bolt pattern may be the same though, not sure.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. |
09-07-2004, 11:14 PM | #16 |
See jetchip.com for info on auto overdrive trans. For the manual types the T-5 can be made stout but the better choice is the T-56.
09-08-2004, 06:00 PM | #17 |
A classic GM kinda guy
Websites to look at:
For manual transmissions: www.keislerauto.com
For automatics:www.bowtieoverdrives.com These should give you all the info you need.
Old school rap music: a dual exhausted GM 6 with no mufflers. "If you can find a better vehicle, buy it" Lee Iacocca, Chrysler commercials of the '80s. "I did. They are called Classic GM pickups !!!" |
09-08-2004, 06:38 PM | #18 |
Awesome website, all the info I need to know expect how much is a fair price to pay for a 2004R, there is one here for sale from a La sabre with 20,000 miles on it. Anything I should look for when buying a used tranny?
09-08-2004, 07:37 PM | #19 |
dont look for a used automatic to just put in and go basically you want a core and have it built to handle what your going to throw at it otherwise you will be unhappy when it blows up the first time you rip into the throttle
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
09-08-2004, 08:59 PM | #20 |
I've dropped a 200R4 in my truck. Everything's bolting right up to it. Seems like there was another thread in this forum just a few days ago, b/c I posted to it also. I bought a rebuilt 200R4 with all of the kevlar components, etc for $650 + 125 for the TC. The guy I bought it from lives in So. Illinois. I can give you his number if you like.
09-08-2004, 10:18 PM | #21 |
It will be behind a 250 in my Jimmy so I don't think I have to worry about ripping it to shreads with all my horsepower. The one that is for sale here they want $150 for it and it comes with a TC.
