Old 09-04-2004, 10:25 PM   #1
airborne3502
bedside removal question
hey guys,
I'm taking my SWB fleetside bed apart. sort of....
I've removed the tailgate..
I've removed the front bed panel...
I've removed the inner wheel panels...
I've removed all of the bed bolts and the bedsides still feel pretty attached in the back.
What did I miss? Are they welded back there?
While I've got ya'll here...
Where/How do I disconnect the wiring to the tailight lenses & reverse lights?
Thanks in advance
airborne3502 is offline   Reply With Quote
Old 09-04-2004, 10:32 PM   #2
chucks70
The bedsides are welded in the back, tack welds where the post meets the steel bed or the bed sill. The wiring has a connector underneath you'll need to seperate. Take the lens off and remove the screws that hold the light housing to the bedside and pull it out with the wire. Go slow so you don't skin the wire or tear off the connector.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 09-05-2004, 12:48 AM   #3
airborne3502
thanks chuck,
I really appreciate you taking the time to help me out!
