MOTORHEAD!
should I go 350, 383, or 400??
I am building an engine for my truck and I have everything decided except for choosing the displacement.
What I have right now for parts are the edelbrock perf. rpm heads, RPM air gap, crane 1.6 roller rockers, comp XE274 cam and misc other goodies. I would like to be over 400hp with this engine and would like to have respectable 1/4 mile times as well. Tranny and converter suggestions are also welcome!! Thanks, 910
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
Go with the 383 if for no other reason than the greater amount of torque created by the longer stroke. You can use stock length rods, just need pistons for the longer stroke (pin is located lower on the piston skirt). Good luck and keep on truckin'.................Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake 600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash |
I agree with jlmtrout. 383
Good Luck, Jeff
72 C10 Burb 350 700R4 70 C20 LWB 350 Crate TH400 68 Chevelle |
Saving 1 truck at a time!
400...displacement and stroke...best of both worlds!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
My brother-in-law had a 400 in his 4x4. He complained about "spider-web" cracks in the heads, plus something about "siamesed" ports that he didn't like. If you get after market heads, they will have to have steam holes drilled in them. Plus, good 400 blocks are getting harder to find that are in decent shape. Good luck and keep on truckin'...............Jerry
its all about the +6 inches
400 2 bolt main.
Watch out for your cornhole !
![]() Join Date: Jun 2003
400- All the stroke that the 383 has, but even more displacement.
It takes about 5 minutes to drill the steam holes in the heads. Tons of engines have siamesed bores and they run fine. 400 problems are a myth.
turbo 400 tranny to a 400 2-bolt and you'll be running low 11's on the 1/4 mile.
Man I need another 67-72!!! ![]() |
MOTORHEAD!
I have an guy wanting to sell me his 400 4 bolt short block for $350 CAN. The block is not bored but the crank, rods etc have about 200 000 miles on them. Is it too risky to buy this and hope everything else inside is fine??
The 350 I have (73 Z28 4 Bolt) Has a very strong bottom end with 10:1 flat tops. The engine was rebuilt about 40 000 miles ago. It was basically built to spec of about 245hp, but now I have all these new parts that I'm itchin' to use. Would anyone here put the all the work into the top end when the bottom end has 40K on it?? Will the bottom end last??? Is anyone here running the XE274 cam, Tell me what you think of it! Thanks 910
Got Light Emitting Diode?
since you have a 350 that would probably be the way to go, building a 383 would be more expensive than rebuilding that 400, and like said before steam holes only take 5 minutes to drill. so far i love my 400. i got it pretty hot a few times when i was stuck in traffic on 100+ days and no problems. most of the horror stories that people have about 400s the steam holes wernt drilled right or at all on the heads that they put on
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
400 and I'm a big fan of the 700r4 trans to go with it. Lower 1st gear and overdrive.....can't beat it.
MOTORHEAD!
What were the 400sb 4 bolt main 70-72 engines installed in? I assume they were in vans and 3/4 tons
910
#13 |
Have another!!
400 block 350 crank 6.0 rods. 377 destroke it, tightest rapen sun a gun
#14 | |
ummmm...may be in a 2500lb ride..in a 4000lb ride low 13s would be respectable with a 400HP 400ci engine, might even squeak into the 12s if all of the planets line up right
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
#15 |
MOTORHEAD!
Yeah, I thought 11's was quite optimistic, I am hoping to run 14 flat or better.
I am planning on running 3.73 with a 28 inch tire, what stall converter do you guy's recommend for the XE274 with this setup? I am planning on removing the original powerglide and dropping in a TH350. The truck is going to be used about 70% cruisin and 30% dragging. I was thinking in the 2800 range but I am not sure if this is too much or too little. thanks 910
#16 |
Oilfield Trash
377 man, wicked power, run all the good stuff on the bottom end cap it with 64cc heads, 10to1 compression she'll freakin rip hard.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
#17 |
MOTORHEAD!
What is the stroke length of the 377???
#18 |
you're going to need good aftermarket heads on any high performance motor. I like Dart personally.
68 short step, 406/700r4, 9" w/discs. |
#19 |
The stroke of a 377 is the same as 350.......3.48"
#20 |
JMO but those heads are a little on the small side (170cc) for a 400. Great for low end but top end will probably fall off some.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
#21 |
![]() Join Date: Mar 2003
thanks 910[/QUOTE] What is the power band of the cam--also I would figure out how many cubes you want that cam to work with before you order up a convertor. the amount of cubic inches will change the torque band. For example I have used the same cam [crane268] in a 350 and a 400 and got totally different results with power, lope and rpm. |
#22 |
Fabricate till you "puke"
If you go for a 377 (thought about that hard, as I have a butt load of gears). Go for an aftermarket crank, scat or Eagle should be able to put you into a 3.5 stroke....just a tick longer that a stock 350 crank. She will make a few more cubes(381-382...didnt do the math). the big thing , is thatthe aftermarket crank can be had with the stock 400sb main journal sizing(no bearing spacers. I would build that one with a 6" long rod, & rev it to the moon with my 6 gear trans.....bet it would beat the "toad snot" out of a 383(upstairs). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#23 |
MOTORHEAD!
So lets just say I assemble my 355 with the XE274 cam, 1.6 roller rockers, Performer RPM 64cc heads, RPM Air-Gap Intake , and leave the bottom end the way it is, (10:1 Flat tops). What can I expect this engine to produce??
Also the XE274 is a .490 lift cam, correct me if I'm wrong but with the 1.6 rockers, will my lift actually be .523??? And if so, with this combination should I be worried about piston to valve clearance?? Thanks 910
#24 |
if you actually end upwith 10-1 compression, then it should be a nice combo. Add a 2800-3200 stall and it will get up and go. PV clearance should'nt be a problem..but check it anyways..The reason I said if you actually end up with 10-1 is because the head CC's and piston valve reliefs are not always what the box says
#25 |
MOTORHEAD!
Yeah the guy at the speed shopsaid it would most likely be around 10.4:1.
bigjimzlll- What have you done to your engine to make your truck so fast, are you running a hyd. roller cam???
