Almost done!
373 Rear End F/S DFW $25.00
I have a extra 6 lug rear end out of my '70. I bought a 308 5 lug and swapped out.
This is the late model '70 rear end that will interchange the 5 lug axle shafts if you are wanting to convert a pre '70 truck from 6 lug to 5. I had to pull the pin out of the spider gear set to use in my 308, so I am letting this go cheap $25.00. You should be able to pull the pin out of your existing rear end to make work. I can show you how to do that, it is easy. I even have three 5 lug steel wheels I can throw in. I will not ship it.
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
The oddest Todd around
posi?
all I need is the carrier (ring and pinion)...(you can keep the rest)... let me know if it is posi as well and throw me first in line for right now.
Todd |
Almost done!
Sorry guys, not a posi.
Toddtheodd, you can have it all, it is in my way. I'll help you pull the gears, but you have to haul the rest away too.
I'll have to pass due to my wanting a posi.
I want the burn marks to be even ![]() Though if nobody else takes it, I will take it, just to get the 3.73. Put me last in line as a definite. Todd |
Almost done!
I have to get rid of the whole thing, it is taking up way too much flor space. I am sure someone will jump on it pretty quick, the price is too good.
Well, I don't even get off of work today until 6pm. If it's not sold by then..........
Keller isn't that far from North Richland Hills. ![]() |
If the housing will take the 72 five lug axle I will take the Housing off Thats all I want
I've got it now. It's a 12 bolt by the way.
I guess I should if you have someone wants the gears I will take the rest of it I have a 69 rear end with 72 axels.
Almost done!
You might be able to talk Todd out of the housing, he bought it. I think he only wants the gears.
