Old 09-05-2004, 02:17 PM   #1
ScottH
ScottH's Avatar
Need help with heater problem
Hey guys, well finally got the chance to look at my 72 blower not working. Turns out the blower relay wasn't there, PO did some "creative" wiring on this truck. Anyway got it to work while the relay is on order. Problem I'm having is no matter where I have the controls, all the air blows out of the a/c vents. I'm trying to make sure I have heat and defrosters for the cool weather. The cables seem to be moving, but nothing out of the floor vent or the defrosters regardless of where I move the controls.
Any help or suggestions would be appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 09-05-2004, 04:54 PM   #2
neonlarry
neonlarry's Avatar
Check the flapper valve in your diverter box, I bet it is broken.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-05-2004, 10:57 PM   #3
ScottH
ScottH's Avatar
Thanks Neonlarry, can u tell me how I can get to it?
Old 09-05-2004, 11:51 PM   #4
neonlarry
neonlarry's Avatar
This is a pic of diverter box under dash. The flapper valve is in the center it usually breaks along the shaft it pivots on.
Old 09-06-2004, 12:02 PM   #5
ScottH
ScottH's Avatar
Thanks again, I found it and pushed it back so the air is flowing where I need it for now.
Thanks for all your help.
Old 09-06-2004, 02:44 PM   #6
neonlarry
neonlarry's Avatar
Some people have been able to repair the broken valve using some metal straps or fiberglass. Sure beats paying for a new one.
Old 09-06-2004, 09:08 PM   #7
ScottH
ScottH's Avatar
I'll have to check it out better. BTW I installed a new blower motor and blow relay but the blower still doesn't work correctly on high. It does work, but at the same speed as the previous setting. Any ideas?
Thanks again.
Old 09-06-2004, 09:49 PM   #8
Harold Shepard
Your switch may be bad at the high position, it is just a slide switch moving across contact points and they burn up after a time, it could be the next easy check for you.
Harold Shepard is offline   Reply With Quote
Old 09-06-2004, 10:41 PM   #9
jhow66
jhow66's Avatar
When you installed the relay did you make sure the relay was getting a good ground (black wire that hooks to the relay mounting screw). To check your ground run a jumper wire from the relay to a good ground.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 09-07-2004, 09:41 AM   #10
ScottH
ScottH's Avatar
thanks guys....I did make sure I was getting power from the switch on high position, but did not attached the ground wire. The end of off it and I was in a bit of a hurry. I'll properly mount and attach the ground and see what happens.
thanks again.
