Old 09-05-2004, 04:07 PM   #1
tough82
Brake system question
I need to get a new master cylinder. How do I tell what kind of brake system I have? The factory sticker that was supposed to be in the glove box is gone. Anybody have any idea? Autozone has three options:
#1 - JD3, JD5, JD6
#2 - JB3, JB5, JB6
#3 - JB7, JD7
What is the difference? I have an 82 K-2500 with 1-ton axles, any suggestions? Thanks.
Luke
82 K-2500, 8" Lift, 1-ton running gear, still deciding on the tires
tough82 is offline   Reply With Quote
Old 09-05-2004, 04:30 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Did you check the driverside wheel well / inner fender area under the hood? Im not sure what rpo it would be for 3/4 4x4. The JD5 is the heavy duty brake system for a 1/2 ton.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-05-2004, 04:40 PM   #3
tough82
There is no other info under the hood. Thanks for your input.
Old 09-05-2004, 07:21 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
Maybe you can take the old master with you and match it, if you can get the dummies at Nozone to pull them for you. Other than this, I don't know how you can tell.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-05-2004, 09:56 PM   #5
tough82
Yeah, I guess I'll do that, if I find the old one. Tore everything down a while ago. Thanks
Old 09-06-2004, 06:29 PM   #6
tough82
Spongy brakes
Ok, got my new master cylinder. Everything looks good, bled the brakes 3 times, no bubbles at all, but the brake pedal is still spongy and the truck does not stop good at all. I'm using a 1/2 ton 2wd brake booster in my 3/4 ton 4wd truck. Maybe that is my problem?? Any suggestions?? Thanks
Old 09-06-2004, 06:55 PM   #7
swervin ervin
Did you bench bleed the master cylinder?
Old 09-06-2004, 07:15 PM   #8
tough82
Yes I did.
