09-05-2004, 06:51 PM | #1 |
Oilfield Trash
ignition switch removal help (cant search)
i know this has been brought up before but how do u get the ignition switch out of a 71?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
09-05-2004, 06:53 PM | #2 |
there is a little hole on the front of the switch, put the key in and turn it to the right to the acc. position. next push something small and hard into the hole you will fell it depress then turn the switch counterclock-wise until it stops, you may have to do this several times until it is freely moving. Then using the key remove the switch through the front of bezel.
Man I need another 67-72!!! |
09-05-2004, 06:55 PM | #3 |
Oilfield Trash
put in the pin then turn or the other way around? After that the bezel should just screw out?
09-05-2004, 07:47 PM | #4 |
Just did this today...
The first post is correct. Insert key, turn to accessory position Insert paper clip or similar into hole, you'll feel it depress. (as mentioned) Turn key (lock assembly) counter clockwise and it should come out. Then, yes the bezel just unscrews. Keep trying, it almost never seems to work the first time... |
09-05-2004, 08:18 PM | #5 |
Nope it will almost NEVER work the first time!! I did it atleast 15+ times before it worked I was ready to take a power hammer to it, just keep at it though.
09-05-2004, 10:27 PM | #6 |
JB-80 "Twice as Good"
The big P is the key......patience!!
HEY NOW! |
09-06-2004, 06:14 AM | #7 |
I use liquid graphite before trying.
It flows throught the lock and lubes everything, usually making it easier to get out. Don't get the graphite on your cloths, it will stain them.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
09-06-2004, 09:49 AM | #8 |
67-72 Addict!
They actually make a special tool to safely remove the bezel portion.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-06-2004, 12:19 PM | #9 |
Thats the Hillbilly way
A little WD-40 also helps
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
