Old 09-06-2004, 05:32 AM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Well, surprise, surprise, SURPRISE!
So I went to pick up the rear end from MACKL that I purchased today as one happy individual. When I called him for directions I found out that the rear end was a 12 bolt.
Well.
When I got over there to pick it up I noticed something for the first time. My truck has a 12 bolt as well. I've never really looked under my baby before and always just assumed that it was a 10 bolt.
So tell me this guys. What is a 3.08 non-posi 12 bolt coil spring rear end worth? Because after I get the 3.73's in mine I won't need the 3.08's anymore.
Also. How much does a posi run for a 12 bolt?
Todd
toddtheodd is offline   Reply With Quote
Old 09-06-2004, 06:40 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
No 10 bolts under these trucks. Even the lowly six cylinder trucks, like mine, came with 12 bolts.
Old 09-06-2004, 07:00 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
The six cylinder trucks came with the 12 bolt 3.73 gears standard from what I've learned. My stepside has it.
Nothing all that special about these 12 bolts unlike finding one in a car. Two different animals.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 09-06-2004, 07:23 AM   #4
dennis111
dennis111's Avatar
Not sure if I totally agree with this. I bought my 68' GMC (then 307ci, 3speed, 60,000miles) in 74' and it had a 10 bolt with a 3:42 ratio. Has since been updated with a 12 bolt.
Anyways, just an observation. . . . .
Dennis
68 GMC SWB Custom 1/2 ton, 2WD, 350 V8, PS, PB, 3-Speed, 3:08 12 bolt rear, tilt, tach, vac, cruise and more. . . .
dennis111 is offline   Reply With Quote
Old 09-06-2004, 07:51 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That rear had to have been swapped in. There was no 3.42 gears in these tricks either.
Old 09-06-2004, 08:24 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
my '68 GMC came with a 250, NP435?, & dana 44 with 3.54:1 on leaf springs.
I wish I had kept that.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-06-2004, 08:32 AM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
67-68 GMC's were available with Dana 44's. I also have a 68 burb with a Dana 44 and a posi 3.54 in back.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 09-06-2004, 09:06 AM   #8
frogsmakr
frogsmakr's Avatar
i think that GMCs had DANAs.
frogsmakr is offline   Reply With Quote
Old 09-06-2004, 05:18 PM   #9
Longhorn Man
A dana could be had in chevy or GMC trucks, but the base model rear was a 12 bolt
Old 09-06-2004, 06:13 PM   #10
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Mine has a 10 bolt with optional 4:11's.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 09-06-2004, 06:50 PM   #11
1969 GMC
1969 GMC's Avatar
some early GMC 1/2 tons (usually '68 BB models) had dana 60 semifloater rearends, and then there was also the dana 44 rear, which I can't recall ever hearing of under a chevy.
robert1970c20rstbukt, your truck is a 3/4 ton and has an Eaton rearend. 4.11 should be the standard ratio for that axle w/ 350.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-06-2004, 09:48 PM   #12
OK, thanks for the info. I thought they were optional, but I was thinking about 1/2 tons.
RJD
Old 09-07-2004, 07:07 AM   #13
dennis111
dennis111's Avatar
Even after 30 years of ownership, one can still learn something about their truck. Thanks guys!
Dennis
