Old 09-06-2004, 04:52 PM   #1
MrGoodpliers
MrGoodpliers's Avatar
Weak spark problems...
I'm trying to fire my engine for the first time, and I'm having some trouble. Stock 396 new:cap,rotor,points,condenser,coil,plugs,wires,starter,engine harness. I turned the engine to about 7 degrees BTDC and set the rotor pointing directly at the #1 position. When I disconnect the plug wire, the spark is yellow/orange and will only jump about 1/8-1/4 inch. My points are set to the thickness of the cardboard box they came in (MrGoodpliers style). Any ideas?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 09-06-2004, 06:57 PM   #2
rage'nrat638
rage'nrat638's Avatar
Thumbs up maybe
just bought a set of point's today.....supposed to be set at .019
as per auto zone......
also the stock dizzy should have a resistor wire to the coil....
full 12 volt's maybe to much.....
thats all i know.....
anybody else!!!!!!
rage'nrat638 is offline   Reply With Quote
Old 09-07-2004, 12:00 AM   #3
ZOOMY
spark
During cranking, there should be 12 volts across the points if it's still wired correctly. This voltage then drops to about 8 volts running to keep from burning the points. The spark should be blue. An orange/red/yelow spark is a weak spark. Did you replace the condensor ? If yes, then check for high resistance connections or a weak coil.
ZOOMY is offline   Reply With Quote
