![]() Join Date: Nov 2003
What do I set my timing at? 350 with TPI
I am setting the timing on my truck. I just put my TPI on my 350. Usually I set by sound, and then cruise around and make sure it isn't pinging, but I want a ball-park figure to set it at.
Is it any different with the HEI and TPI on it?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
blood type; Retumbo
disconnect the tan-black wire connector & set it @ 0*. turn engine off. disconnect batt for 30 seconds to clear the code 43. reconnect wire & batt. install bed, open gate, start engine, put in D, drive down here, do burn-outs!
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I set my Base timing at 6*.You can go anywhare from 6-10 base Timeing.(with TAN wire disconnected at HEI)
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Insert funny comment.
![]() Join Date: Dec 1999
I like starting at 6 on TPI as well.
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
