Old 09-06-2004, 09:00 PM   #1
71Rat
ran out of money
71Rat's Avatar
sidemarker filler with blazer tank?
has anyone done a sidemarker fuller with a blazer tank and how do you go about it and what parts do you need? i have seen a write up for it on a step side but havent found one for a fleetside. i have a long bed fleetside and was wondering if i should go about it in this direction or try to do something else. any input would be helpful
Thanks a lot
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 09-06-2004, 09:03 PM   #2
OhioDan
OhioDan's Avatar
Here ya go.
http://www.classicheartbeat.com/mark...t_gas_door.htm
Hope this helps?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 09-07-2004, 01:08 PM   #3
71Rat
ran out of money
71Rat's Avatar
thanks for the reply helps a little
Old 09-07-2004, 07:00 PM   #4
Red68
Red68's Avatar
71rat,
I just finished doing this to my 68 fleetside long bed. It wasnt too bad. I used the same instructions that OhioDan recommended. The biggest challange was modifying the s-10 filler tube. Which included reducing it from 2" to 1 1/4" in dia. and routing the filler hose. It took me several cuts and welds to get it right. I used various exhaust reducers that I found at a local swap meet to make it work. It is very slow to fill because of the reduction and the filler hose is nearly flat(no fall to the tank because of the narrow space between the bed and frame). If you can afford it I would go with a aluminum or stainless tank vs. a poly tank. I believe you will get a better fit and the filler tube will work better.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 09-07-2004, 07:34 PM   #5
superfly68
superfly68's Avatar
http://67-72chevytrucks.com/vboard/s...d.php3?t=77104
no longer have a ride, but still a fan!
superfly68 is offline   Reply With Quote
Old 09-07-2004, 07:37 PM   #6
superfly68
superfly68's Avatar
http://67-72chevytrucks.com/vboard/s...d.php3?t=82178
if you have a fleetside...
