09-07-2004, 11:13 PM | #1 |
SKINNY TIRES RULE!
Tire Pressure ?
I noticed the tires looked a little low on my Blazer so I checked the pressure. The tires say the PSI should be at 80. That seems awefully high to me. I've never run more than 35 in any of my car/truck tires. They are LT235/85R16 with an E load rating. Are light truck tires usually higher PSI? Should I fill them to 80 even though my Blazer is probably lighter than a lot of trucks these are designed to be run on?
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
09-07-2004, 11:19 PM | #2 |
The pressure is for the max load rating. Your Blazer will bounce all over the place at 80 psi. 32-38 psi would be about it.
09-07-2004, 11:24 PM | #3 |
80 PSI is cause of the load range e for hauling heavy shiste just run whatever you feel like.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
09-07-2004, 11:26 PM | #4 |
its all about the +6 inches
You need to test out different tire pressures to find the right one for your ride.
You want to have even temperature all the way across the tread. You can do this with a durometer, a lazer non contact thermometer, or with the palm of your hand. I have found in about 90 - 95% of the time, max air pressure listed on the tire is about right. If the tire is designed to hold 80 PSI, then 30 is less than 1/2 filled. This will create WAY too much heat, and the tire can fall apart...think, tractor trailer throwing a re-cap....or picture the Ford Explorers that rolled when the right rear blew out. (they had moronicly low tire pressure becous soccer moms were complaining of the "truck like ride") I would say if you want to fill them up and don't want to bother testing the temperatures across the tread of your tire, go with AT LEAST 75% of the max PSI listed on the tire. Last edited by Longhorn Man; 09-08-2004 at 08:08 PM. |
09-07-2004, 11:49 PM | #5 |
SKINNY TIRES RULE!
Thanks guys. I'm thinking that at max PSI, the tires would be hard as a rock, but on the other hand, I'm concerned about the issues Lonhorn brought up - especially since I take the freeway at 70 mph every day with my baby girl in the back seat. I'll try some different tire pressures, starting around 75% and see how it works. There isn't any noticable wear pattern typical of an under-inflated tire.
09-07-2004, 11:56 PM | #6 |
The real thing to look at here is the tire situation. Why an E rated tire on a Blazer??? WAAY too much tire for it. Longhorn Man is right, they should be inflated properly........but they will ride very hard on that truck.
You wouldn't notice the tire stiffness as much on a vehicle equipped for them. The true cure here is to replace those tires with something more appropriate. |
09-07-2004, 11:59 PM | #7 |
Don't run whaterever you like or fill to 75% of the max. If you own a newer car or truck go out to it and look inside the drivers door for the tire label. It will give the correct pressures for the size of tire used on the vehicle. Then look at the tire and see that the pressure rating is much higher. Just because you can fill a tire to 80 psi, doesn't mean that it will work at that pressure. More air can mean more heat which will mean more pressure. Be careful.
09-08-2004, 12:06 AM | #8 |
do what you want....we tow a 18000 pound gooseneck trailer and have e range tires for that reason on a big 4wd chevy....we have run next to no air and have hit the 85 max....dont make much difference in ride cause it has 2.5 ton springs on it. get more conventional tires and dont have to worry.
09-08-2004, 02:09 AM | #9 |
SKINNY TIRES RULE!
Not sure why it has E rated tires. Definately overkill for the truck. My understanding is that the tires are the stock spec. It has optional (maybe dealer installed) 16" wheels. A PO must have done some hauling with it, because it has a dealer installed step bumper with a hitch, a classIII receiver (valley brand) and trailer brakes.
09-08-2004, 02:31 AM | #10 |
I would change out those tires. Stock rims for a blazer aren't made to handle 80psi.The rubber compound is awfully hard=low traction.Look for tires in load range C. I think you'll be alot happier with the handling & ride.
68 K-10,79 K-10,80 C-30 57 chevy convertible 79 Z28 |
09-08-2004, 04:50 AM | #11 | ||
This is inacurate info, and is a common (misguided) opinion. Again, we can look as the ford explorer. The tires are rated at 40 to 50 or so max. (I am guessing on that) When ford said run the tires at 24 (!!!!) people died. Low tire presure creates heat, and the glue holding the tire together can only handle so much heat. Quote:
Again, bad advice. ESPECIALLY if you are towing/hauling loads. The side wall supports the weight of your vehicle. The pressure inside the tire supports the side wall of the tire. If the air pressure is low, then the sidewalls can not be supported properly. You then get non rigid sidewalls that will let the tire flex and squirm. Zou can frequently feel it in the steering, the vehicle feels loose...or even like a boat. Wandering is another problem, not to mention odd tire wear. Plus there is the whole blow out issue like I mentioned before. |
09-08-2004, 11:16 AM | #12 |
SKINNY TIRES RULE!
Ok, I just called Les Scwab to see what they say. Although he agreed the E rating was a bit overkill, he said they should be just fine. He recommended running in the 40 psi range for everyday driving.
He said there is a formula to figure out the proper psi. Weight of the vehicle/4=X X/max pounds per tire = Z Z /max tire presure = % of actual PSI. I hope I didn't miss a step, but this sounds reasonable.
09-08-2004, 11:19 AM | #13 |
The only bad advice is from Longhorn Man. As far as the Ford issue, can you say TIRE DEFECT. AAA estimates 15% of drivers have improper tire inflation and the NHTSA recommends using the vehicle tire label pressures.
09-08-2004, 03:56 PM | #14 |
Great thread. My 2 cents: The heat comes from the flexing of the sidewalls. More pressure reduces the flexing and so reduces the heat buildup. More pressure also reduces rolling resistance which improves gas mileage. I have a 1-ton C30 with duallies. They are rated for 60 p.s.i. I have 42 psi in them now but after reading this thread will boost each to 60.
09-08-2004, 04:04 PM | #15 |
The LuvShack Garage
For what it is worth, here is my experiance with the wife's ride.
99 Trailblazer - Factory tires - Goodyear wrangler a/t's I think Max pressure was listed at 44 psi, I ran 40, everyone told me that it was to much, pulled them off at 95,000 miles and still had a ways to go on the thread indicaters, replaced with set of Michelan cross terrain suv's, Max pressure is listed 36 psi, running 30, and I hope they outlast the darn blazer. My $.02 P.S. - at 118,000 miles now & brakes are OE & still look new.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
09-08-2004, 05:02 PM | #16 | ||
As far as NHTSA goes, I'll believe the tire companies, and indy car pit crews before I'd listen to them. And yes, I have spoken to reps from BFG, good year and michilin when i did a report in high school. And also, as far as the indy car pit crews, My boss is the tire guy for one of the teams, I have met Mario Andreti, and some other indy yahoos. We (my boss and I) spent hrs just talkin to the pit guys as they showed us all the stuff they do, torn down motors, trannys in a million pieces, and there shop was spotless too. Totally awsome. Team andreti spend about 1/2 a million in tire research alone last year. Untill the desk jockeys at NHTSA can match any of this, I could care less than what they say. More proof? Look at LUV2XCLR8's post...just shy of 100K on OE tires! I knew a guy in Tx who had done the same thing. He removed the OE tires off his 82 ram charger at 110K becouse they were dry roted so bad it was scarey. Still had plenty of tread left too. Quote:
09-08-2004, 07:18 PM | #17 | ||||
You don't necessarily need to run a max pressure at all times but I wouldn't go more than 10-15% below that though. aesj2....When you call someone out like that Quote:
I stand by my original statement "Too much tire" the is no need for an E rated tire and I wouldn't run it underinflated to soften the ride. It's a band-aid on a broken arm. |
09-08-2004, 07:48 PM | #18 |
aejs to call someone out like that is wrong especially someone who is right the tire problem was fords fault they just happen to have more money than firestone. every tire that blew was underinflated not a tired problem. there are still 10's of thousands of firestone tires on the road that havent had a problem. the sticker in the door dont mean sh!t you need to look at the tire. the rating in the door are for the tires that came on the vehicle from the factory and sometimes they arent accurate
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
09-08-2004, 08:21 PM | #19 |
You know, i didn't even read his responce 100% correctly. I read it as me being wrong about the ford and then a statistic thrown in. (remeber, 85% of statistics thrown out there to prove a point, are made up on the spot)
I did not realize he was saying that everything I said was bad advice. Thank you longhair and cableguy...2 mechanics who know whats up....unlike the Engineers who always THINK they are right (click on his profile), but in reality, just have problems with over thinking things. AAA is insurance, they don't test tires. NHTSA comes up with rediculousely low speeds in off ramps and other stupid 'safety' items...they don't spend any money on testing tires. Without getting cockey, I have been involved in (personal) tire testing per the advice of three of the biggest (US) tire makers, and a few of the Indy pit crews...again...I'll listen to what has been proven, not just what has been recomended. |
09-08-2004, 08:34 PM | #20 |
I keep my tires at 40, and the spare is at 50. All the tires are 4 ply tread, except the spare which is a 6 ply so it can handle more air.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
09-08-2004, 08:35 PM | #21 |
huh?
I'm with Andy on this one, and most others. When you underinflate a tire drastically, you increase the heat BIG TIME. But then again, I don't get paid 6 figures a year, so I know nothing
At any point, this thread turned into a pissing match of sorts.....sorry to ramble like that. If it were me, I'd run the tires at or just below the max. inflation specs. My friends dad had an original honda civic (early 70's), and got 89,000 miles out of the tires, and they were still on it when he sold the car....all he did was check the tires at every fillup (he's really anal), and kept them filled to spec. The heavy rated tire is gonna mess your ride up some, but I wouldn't underinflate it to compensate, I think it'd be a really bad idea.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay Last edited by 68 Stepside; 09-08-2004 at 08:36 PM. Reason: can't type |
09-08-2004, 09:34 PM | #22 | |
He's got mean nasty FANGS!
Manufacturer specs. are for tire ride, and generally for the OEM tires ONLY. An 80 PSI tire needs to be run at a high pressure to prevent sidewall flexing and heat, and premature wear, it's designed to even out the tread at 70-80 PSI, less will wear the edges prematurely, more will wear the middle prematurely. it also varies base on vehicle weight etc. being that we are driving 30+ yr old trucks originally equipped with bias ply tires, any factory specs are POINTLESS as we run entirely different tire technology now. So why don't you stop your bashing without the proof to back anything up, and quietly leave this thread/board if you have nothing positive to contribute.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
09-09-2004, 10:41 AM | #23 |
NOTHING I have stated is made up. Check the web for the info. Firestone still has problems - check the GM tire recall. Again, the deal is for MAX LOAD.
See reply #11 - let's not tell people to go away because they respond. As for me, I'm a mechanic (ASE and State of MI)for 21 years, engineering test techinican for 12 of those and full time crew for a SCCA race team for 7. Have a nice day. |
09-09-2004, 11:19 AM | #24 |
SKINNY TIRES RULE!
Hum, I didn't mean to start a war here guys. I just wanted to know if I should be running 80 PSI or less.
Is everyone saying that the guy at the tire store was incorrect?
09-09-2004, 10:39 PM | #25 | |
