Old 09-08-2004, 04:45 AM   #1
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Rear Coil spring lowering question
Do the springs have to mount top and bottom ? I was wondering if I could trim part of a top coil off. Or does it need both ends to mount ? Thanks
I was also wondering how to use a lowering block on these trucks ? Drill 2 holes for the U bolt or should I buy the more expensive 2 hole blocks ? thanks
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 09-08-2004, 08:51 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The springs need to be secured top and bottom.
It's easy to make lowering blocks for these trucks. Just use thick wall square tubing and longer u-bolts. Two inches is about the max though or you'll run into scrub line problems.
