Old 09-08-2004, 11:16 AM   #1
TwinTurbo
TwinTurbo's Avatar
What's the light blue/ green wiring for??
What's this wiring for? The wiring comes through the firewall through a small hole just left from the fusebox. Is this from the cruis control system???
Marck
TwinTurbo is offline   Reply With Quote
Old 09-08-2004, 12:40 PM   #2
smokinn
smokinn's Avatar
What year and motor size might help.
smokinn is offline   Reply With Quote
Old 09-08-2004, 12:41 PM   #3
TwinTurbo
TwinTurbo's Avatar
83 used to be 305 / TH350
Old 09-08-2004, 01:21 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
On my 85, there is a grommet beside the fuse box, engine side. It's not a flat grommet but bulges out. Anyway there is a light blue wire and a green wire coming out. The light blue wire goes to the low vac switch for tranny lockup. The green wire goes to the coolant temp sender. Is your TH350 a TH350C with lockup?
Hope this helps.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-08-2004, 04:34 PM   #5
TwinTurbo
TwinTurbo's Avatar
Mine has a 400 now. The blue and green wire share a connector
Old 09-08-2004, 07:41 PM   #6
swervin ervin
I have changed so much wiring on mine, it may not be the same. I can't remember if I've changed any wiring coming out the grommet or not. It's very possible that both wires at one time went to the low vac switch. The stock wiring for the lockup was a total mess with wires going every which way. My wires may just be where I reran my lockup which consists of one wire now, and the other (green) wire may be where I ran a new temp sender wire. I'm just not sure.
Do you have a low vac switch still mounted on the firewall, or did you ever have one? If you do, see if the plug fits the switch. It's a tiny plug and will only fit it and nothing else.
Old 09-08-2004, 07:51 PM   #7
MidnightBlues
Hi Marc,
The green wire is a test wire for the (low vac switch) lockup system.
The blue wire is supposed to go to the brake cancel switch.
But you don't need all this with a 400 tranny.
greetz :p
*Andre*
1984 C10 SWB, 350/700R4
MidnightBlues is offline   Reply With Quote
Old 09-08-2004, 08:04 PM   #8
TwinTurbo
TwinTurbo's Avatar
ahh.thanks, torque converter lockup control ... don't need that indeed
