09-08-2004, 09:37 PM | #1 |
67 is sold
dash disassembly?
I started to strip the inside of my cab tonight.
I got every thing out except he instrument cluster. For the life of me I can't get the wiper switch, headlamp switch or choke cable out of the dash Heater is out, dash harness, wiper motor, dash pad (nice work not just cliping it in the top GM) It looks like the switch bezels spin (there are two square holes in the face) but it doesn't apppear they do?? Any tips |
09-08-2004, 09:47 PM | #2 |
67-72 Addict!
Those chrome pieces are threaded. The wiper switch has a tiny screw under the knob. The headlight knob has to be pulled out and then you reach behind the bezel and press the button on top of the switch to pull the rod out. Also have to unplug the harness, disconnect speedo cable and oil line.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-08-2004, 10:05 PM | #3 |
removal
here's what I use , if it helps. loose the little screw to remove the knob and the pliers to loose the thingy with the 2 holes in it. only thing left is a nut,9/16 I think, then the swithch will come out if you have it disconnected. the light switch has a little push botton on the top of it which you need to push down and at the same time pull thelight switch on, then the rod will come out with the knob on it. hope that helps.
looks like 70c10 responded as I was typing, but here ya go.......... |
09-08-2004, 11:19 PM | #4 |
heres a pic of the button on the light switch you are trying to feel for up under the dash
09-09-2004, 08:31 AM | #5 | |
67 is sold
Solver - Oops, I undid the clips on the top piece of that switch and got a face full of springs and copper contacts LOL :p |
09-09-2004, 11:16 AM | #6 |
Custer had a plan too.
There is a trick to removing the light handle/rod. First, you have to locate the button to release the rod. Pull the switch to turn the lights on, THEN depress the little button and the rod will come right out. If you depress the button then pull the rod from the off position it will not come out.
I got so mad until I figured this out. |
09-09-2004, 12:39 PM | #7 |
1FINE69
Headlight switch
Joe, if you need a new switch I have one I'll give ya. Let me know. We could meet somewhere so you can pick it up.
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
09-09-2004, 12:44 PM | #8 | |
67 is sold
09-09-2004, 11:15 PM | #9 |
Remember when you get the light switch rod out, your lights will be turned on.
09-10-2004, 07:10 AM | #10 | |
67 is sold
09-11-2004, 10:38 AM | #11 |
Listening since '86
yeah, you don't want to remove them like I did - with a pair of pliers!!! Now I have to look for a new light switch stem/knob, and a new wiper knob. Okay, the wiper knob was already toast but still.
DO IT THE PROPER WAY!!
2007 Saturn Aura - hey it WAS a GM product |
09-11-2004, 10:43 AM | #12 |
67 is sold
Dash is totally disassembled - thanks for the tips
