Old 09-08-2004, 10:08 PM   #1
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Window Crank and Door Handle Removal
I cannot get those things off. I know there is a pin or spring that holds them on but no luck. Any tips, advise, prayers are all welcome. Idiot proof pictures would be great.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 09-08-2004, 10:14 PM   #2
Joe67
67 is sold
You need to visit the local auto parts store and pick up a window crank removal tool for a few bucks
There is a C clip behind each handle, use the tool like this:
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 09-08-2004, 10:15 PM   #3
71swb4x4
71swb4x4's Avatar
I alwys use a screw driver to gently pry the handle out a bit and a needle nose plier or tweezer to grab the clip. It would be much easier to by the right tool though.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-08-2004, 11:06 PM   #4
jimfulco
I use a piece of coathanger wire with a 1"x3" loop on one end for maneuverability, & a tiny hook (bent, then cut) on the other end that grabs the clip in the center. Watch those clips, they tend to fly out of sight real fast.
jimfulco is offline   Reply With Quote
Old 09-08-2004, 11:23 PM   #5
67cst
i love summertime
67cst's Avatar
even with that tool it can be a pain in the arse, especially if those clips get bent, ive found that the original clips work a lot better then the ones on the help rack at the parts store too, so like jimfulco says, dont let them go flyin!
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 09-08-2004, 11:51 PM   #6
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i have used the red shop rags before. terry cloth works too but kinda thick.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 09-09-2004, 07:46 AM   #7
mrein3
mrein3's Avatar
I bought one of the tools 67c10step has pictured above after about 10 years of trying to use the methods others talked about.
BUY THE TOOL
Not having that tool is like trying to remove a phillips head screw with a coat hanger.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-09-2004, 07:58 AM   #8
Blue Beard
Blue Beard's Avatar
I've got one of those tools, been using it for years.
Some other methods will cause damage.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 09-09-2004, 08:28 AM   #9
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
Go buy the tool. Best $4 I ever spent...
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 09-09-2004, 10:07 AM   #10
A few 72's
A few 72's's Avatar
I have one of the removal tools, but have also used the free paint can openers from the hardware stores. Slide the curved tip under the handle and it will fit around the center of the clip. Just pull the clip out.
A few 72's is offline   Reply With Quote
Old 09-09-2004, 04:13 PM   #11
Iminocca
The clip removal tool is well woth the money! Since no one else mentioned it, you don't need the tool for reinstalling the clip, just push the clip all the way back in place and slip the handle back on to the shaft. The end of the shaft is tapered and the clip slips over it and locks into place. Took me a couple of years to figure that one out!
Patrick
'71 C20 Camper Special
Iminocca is offline   Reply With Quote
Old 09-09-2004, 05:32 PM   #12
Dick Dale
Dick Dale's Avatar
I got them off. Driver side window was stubborn, and thank god I am replacing the panels.
Budget 350 Build
