Junior Member
rough idle has me stumped
Aquired a 1970 GMC 350 auto,quad, automatic. Truck runs great as soon as it comes off idle, but at idle the whole truck just shudders. Thought it was a vacuum leak, but could not find one. replaced all hoses just for good measure. Then I found Champion plugs and off-brand points, so they went away. I then went into my fit to be tied mode and changed the entire ignition system over to HEI,(don't tell shuttermutt where I got the parts).With timing at 8 degrees and idle set at 950 (no load), it becomes almost bearable, but still not right. Exhaust sounds like a steady miss, but when I pull plug wires,none of them fail to drop rpm's about 75 to 100. Compression is a little low at 90, but no more than 5 to 7 lbs difference between cylinders and that was on opposite banks. Any ideas before the rest of my hair comes out?
72 C10 10 yr.daily driver 68 C10 18 yr.money pit 72 Nova all original 99 H.D. Heritage[sanity check] 71 VW topless bug[summer fun] "When I have the money, I don't have the time ; when I have the time, I don't have the money. |
