Old 09-09-2004, 06:42 PM   #1
dumpit
4" to a 6" lift?
i have a 4" lift on my 84 pick up. wondering if it was possible 2 change 2 a 6" lift, without having 2 take out the whole 4" lift and buying a full 6" lift kit.
dumpit is offline   Reply With Quote
Old 09-09-2004, 08:14 PM   #2
79Silv4x4
Workaholic
79Silv4x4's Avatar
Well, you will have to (at least) swap some parts--we need more detail. Regardless, you will need new front springs to do it right (my opinion). For the rear:
If you have a 4 inch block now you can install 2 inch springs.
If you have a shackle flip you can install 2 inch springs.
You can install new 6 inch spring also
hope this helps
BTW, depending on everything else, you may need new shocks, brake lines, driveshaft mods, and/or other steering arm/drag link mods
79Silv4x4 is offline   Reply With Quote
Old 09-09-2004, 10:19 PM   #3
1FaastC10
1FaastC10's Avatar
you will need front springs in order to do the front the right way, blocks up front are a big no no. they're illegal in all 50 states.
what do you have for lift now?
1FaastC10 is offline   Reply With Quote
Old 09-10-2004, 12:20 AM   #4
useRc10
useRc10's Avatar
2 inch body lift?
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 09-10-2004, 02:13 AM   #5
1FaastC10
1FaastC10's Avatar
body lift is a cheap easy way to get tire clearance, but overall a bad idea. more leverage on the body mounts and bolts, due to them being longer would make for more body roll, and in time could break the bolts leaving the body free from the frame. not a good thing when you're sitting still, much less trying to drive it. body lift breakages are not common, but they do happen. i have seen 2 personally, fortunately nobody was hurt.
Old 09-10-2004, 08:12 AM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
I agree, when you step up to a 6" your gonna need all of the above plus you will need to re-route the exhaust crossover because it will hit the front shaft.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 09-10-2004, 10:55 AM   #7
dumpit
i got 4" blocks in the back with new shocks and ****.. front i got new springs with shocks....i figured i would need all the extentions for the driveing and **** and brake lines..but i was wondering if it would be expensive 2 go from a 4" 2 a 6" lift
Old 09-10-2004, 04:42 PM   #8
bigarmzz
bigarmzz's Avatar
Talking
i got a 4" lift on my 86, with a 6" lift, ya got to have longer front brake lines, but you can go the cheap way out and get oem front brake lines for a 2wd, there longer, and cheaper at autozone than getter those braded deals for $70 ......you'll also with a 6" lift have to get the driveshaft lengthened.....
you can put 35"s on a 4".....a 6" lift just seems like more buck than bang
-bigarmzz-
bigarmzz is offline   Reply With Quote
Old 09-10-2004, 04:45 PM   #9
bigarmzz
bigarmzz's Avatar
my last one i did last winter...
35" BFG all terrains with 4" superlift
-bigarmzz-
Old 09-10-2004, 08:00 PM   #10
dumpit
aight so 2 go from 4" 2 6" i need 2 lenghthen my brake lines and extend my driveshaft...but would i need 2 take out my whole 4" lift and buy an brand new 6" lift??? i have 4" blocks in back and new springs in front
Old 09-10-2004, 09:02 PM   #11
chevychic
chevychic's Avatar
As stated in the previous posts:
Yes you would have to take out your 4" springs in the front and replace them with 6" springs.
You can keep your 4" blocks in the back and just add 2" springs.
So the answer to your questions is Yes, you would need to take out the front half of your lift (being the front springs) but No, you do not need to remove the blocks in the rear...just add 2" springs and you're ready to make the rest of the adjustments.
ChevyChic
86 Chevy K-10
If I can't be a good example, then I'll just have to be a horrible warning.
"You're braver than you believe, and stronger than you seem, and smarter than you think"
- Christopher Robin
chevychic is offline   Reply With Quote
Old 09-11-2004, 11:46 AM   #12
1FaastC10
1FaastC10's Avatar
good point Heather, but if you're going to the trouble to buy 2" springs, why not just buy 6" springs and be done with it?
Old 09-28-2004, 10:30 AM   #13
gn4u2c
gn4u2c's Avatar
sell the 4' stuff and start over ! do it right or you will never be happy. Get spring lift all around no blocks ! drive shafts done 2 wd break lines and new 6' shocks . small drop for the sway bar steering arm.
gn4u2c is offline   Reply With Quote
