09-09-2004, 09:48 PM | #1 |
Water Injection
HAS anyone ever heard of a water injection or ran one on there vehicle.Just curious.
1964 BBC 402 4x4 |
09-09-2004, 10:00 PM | #2 |
those gizmos been around since the 20's !! the theory sounds great but in real life not much of anything
09-09-2004, 10:06 PM | #3 |
My uncle had this on an old toyota pickup, got better gas milage. I run WI under high boost (20 psi on 93 octane) on my talon to soak up heat from combustion which lowers knock threshold and allows more timing.
1972 Custom 10 Deluxe- original paint, interior- 72k miles http://www.cardomain.com/ride/2466316 Cheap, Fast or Good. Pick any two. 1990 Eagle Talon AWD 1991.5 W250 CTD 1992 Cushman Truckster- Haulster |
09-09-2004, 10:25 PM | #4 |
old trick was real popluar way back when the water raises your compression because water cant be compressed it will make a power difference
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
09-09-2004, 11:28 PM | #5 |
the new Subaru WRX STi has a manual water jet button, but its for the intercooler.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
09-10-2004, 06:04 AM | #6 |
English Chevy Owner
The Ford Escort Cosworth (which like the Subaru was derived from a World Rally Car) had water injection as standard, as above I believe the purpose is to help prevent detonation.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
09-10-2004, 06:18 AM | #7 |
Water injection was used in some of the old aircraft recip motors.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
09-10-2004, 07:05 AM | #8 |
its all about the +6 inches
My 69 had water injection.
Injected it through the block and into the oil pan. |
09-10-2004, 07:12 AM | #9 |
blood type; Retumbo
I was half expecting you to say that Andy.
in theory it is a wonderful idea. the logistics are quite hard to figure out. too much or in the wrong position will just tend to wash the fuel to the side of runners or cylinder. if a person is willing to go through all that they might as well spend the time tuning the fuel & ignition curve while choosing the right cam & engine combo.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
09-10-2004, 09:06 AM | #10 |
ANDY DID IT HELP YOUR GAS MILEAGE?
NAMASTE B&E 1971 LONGHORN C-30 1969 LONGHORN C-20 1968 DUALLY 1970 STEP SIDE PROJECT 1972 CST C-20 1980 M-80 MALIBU FOR SALE 1974 NOVA FOR SALE: |
09-10-2004, 10:17 AM | #11 |
LOL, no, didn't help the MPG too much.
Would you believe the motor ingested over a gallon of coolant in less than 10 miles...yet it ran 100% fine? That's what I get for saying that it was more dependable than gravity huh? |
09-10-2004, 10:33 AM | #12 |
Its used in industrial gas turbines to help meet emissions requirements and was used in aircraft gas turbines to increase the density of the fuel/air mixture which increased power.
09-10-2004, 10:48 AM | #13 |
I BOUGHT A 69 3/4 TON LONG FLEET, JUST FOR THE MOTOR. IT HAD A 1968 427 OUT OF A VETTE. IN IT, & HAD WATER INJECTION ON IT. I REMOVED IT WHEN I PULLED THE MOTOR & TRANS. I REPLACED IT WITH A 305 & A T-350 & SOLD THE TRUCK FOR ALMOST WHAT I PAID FOR IT. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-10-2004, 11:03 AM | #14 |
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
09-10-2004, 01:41 PM | #15 |
Resident Young Old Dude !
In the 70's it was a big fad to run Water Injection, It was a major company, ( Can't seem to remember the name) My brother ran it on a Built Vega Motor, We could never prove any additional power by doing so..
09-10-2004, 04:35 PM | #16 |
My uncle was a service manger for a Cadillac dealer in the early 80s about the time they came about with the motor that would drop cylinders the less power you need. He said people would complain about the pinging so they would put water injection on them to stop it.
09-10-2004, 08:13 PM | #17 |
Water injection was originally used on supercharged aircraft engines in WW2 to help keep them from self destructing from detonation under high boost.
It has also been successfully used on various types of racing engines. These guys make a pretty good system for automotive use, if you 're running a blower or turbo setup. http://www.kennedysdynotune.com/waterinjected.htm
"Negative people always seem to have a problem for every solution" |
09-10-2004, 11:02 PM | #18 |
EddieH., My Dad told me they put 55 gal. drums behind the Pilots seat with Alcohol and water to cool the cylinders. It was neccessary to cool the cylinders climbing after Zeros. That was the only tine they used it and it didn't last long, 3,200 horse radial.
Larry 68 C20 327/465 daily driver 4:56 och! 63 C20 292/420 Camper truck Detroit Locker 4:10 posi 65 C10 ? /powerglide Custom Cab AC,PB,PS,4xflasher 70 C10 250/3spd org/Gauge dash,Wood bed, 4Sale$1300 |
09-11-2004, 08:17 AM | #19 |
You can make a good kit for about $200. 12v DC pump from Northern Tool, Aquamist nozzle, Napa pressure sensor (if needed) tubing, wiring and switches. Aquamist nozzles work the best and are worth the money we have found from our testing.
09-11-2004, 08:49 AM | #20 | |
NOT REALLY BANNED!
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
09-12-2004, 02:03 AM | #21 | |
I dunno...the olds 260 and 350 diesel motors were steeming piles of dung. At least teh Caddy engine can donate a bunch of awsome parts for the bigger 425/472/500 inch big blocks. Although, I am not arguing...they were junk. Most can be had with very few miles...only becouse they didn't run most the time. Dodge does thgis on there new Hemi...glad the computers have come a long way since the caddy atempt. |
09-12-2004, 07:54 AM | #22 |
Watch out for your cornhole !
Most of the 4-6-8 Caddy engines were converted to normal operation by the dealers due to the amount of trouble they caused.
09-12-2004, 09:12 AM | #23 |
Edelbrock made a kit for this back in the late 70s-early 80s.
09-12-2004, 04:31 PM | #24 |
My uncle was an aircraft mechanic during WW2. He told me stories of planes coming back aboard the carrier after a mission with cylinders melted down, or completely gone after they used up all their alcohol/water mixture in a heated dogfight with zeros.
